Switch for heated seats
Old Aug 23, 2004 | 10:02 AM
Edness's Avatar
Hello everyone,
On the way to work this morning I hit the switch for the drivers heated seats and noticed the orange light didn't come on. The passengers heated seat light switch works fine. The heat still comes on for the drivers side and works fine. Is it a pain in the a** to replace the switch? Should I just live with it? I just bought this 99' SE in pristine condition and would like to keep it that way.
Any suggestions or advice would be greatly apprecited.
Thanks in advance.
Edward
Old Aug 23, 2004 | 10:14 AM
MrRogerStatus's Avatar
VQ Disciple
No its not a pain. You'll just need another switch and your regular tools to raise up the console. Or i think you can pull it out and then unplug the wire without removing the console.I don't know i never did mine that way.
Old Aug 23, 2004 | 10:57 AM
97maxxx's Avatar
i have the same problem with mine but both dont work any suggestions? soory to rob ya thread
Old Aug 23, 2004 | 11:05 AM
Maximized Jiggs's Avatar
Same here, both of mine dont work. You are lucky that the passenger side works atleast.
Old Sep 7, 2004 | 02:59 PM
maximaman10's Avatar
Mine is the same way. All you ahve to do is pull the switch out, unplug the wire, plug the new switch in and push it back in the hole.
Old Sep 7, 2004 | 03:18 PM
great, so you are saying the switches are bad and need replacing. How much do they cost at the dealers.
Old Sep 7, 2004 | 03:30 PM
RA030726's Avatar
I'm nutty for Nissans
Dudes...you can replace the light bulb. I did, well I swapped in LED's. But im guessing its gunna be a whole lot easier just getting the whole switch.
Old Sep 7, 2004 | 03:46 PM
Nismo98's Avatar
Please provide a little write-up on how to you did that and what LED did you use.
Andrei
Old Sep 7, 2004 | 07:56 PM
maxima_million's Avatar
How strange, I had the EXACT same thing happen. The drivers switch does not light but the seat does heat up. The passengers side works with no problems! I too am interested in which LED you used to repair the switch! I read somewhere that the switch runs about $45! YIKES!
Old Sep 7, 2004 | 10:07 PM
My problem is that I dont think it works at all, no light and no warm butts in my car. Can it still be the switch or what.
Old Sep 7, 2004 | 10:42 PM
Keyser Skoze's Avatar
im guessing a 3mm LED??? for the switch
Old Sep 8, 2004 | 01:32 PM
RA030726's Avatar
I got some 3mm leds off ebay (with resistors). You could go to radio shack and pick up the stuff you need too.
I took them out of the console, pried them open, took out the stock bulb and orange filter, then soldered in the led and resistor. LED's work only one way so if it doesnt light up than you have the LED backwards. Not to tough really, its good to have a set of pick tools or small flat head screwdrivers when taking them apart.
Old Sep 8, 2004 | 01:36 PM
Nismo98's Avatar
Let see some pics, if not what color LEDs did you use?
Andrei
Old Sep 8, 2004 | 01:46 PM
MaxedOutOfCash's Avatar
Pizda Boy
got the same problem... driver side is not lighting up... passenger is fine.
Old Sep 8, 2004 | 02:07 PM
RA030726's Avatar
LEDs are RED! And we all know that red is the fastest color, LOL. I'll take some pics for you soon okie.
Old Sep 8, 2004 | 02:24 PM
Nismo98's Avatar
Andrei
Old Sep 8, 2004 | 04:54 PM
RA030726's Avatar
Here is a pic, woo woo!
Old Sep 8, 2004 | 05:11 PM
I wanna know what the deal is with mine, how did you take the switch out?
Old Sep 8, 2004 | 07:05 PM
Pizda Boy
i suggest *(i'm not sure but that makes sense to me)* taking the cupholder out & see if you can get through to to the switches from underneath & just pop them out...
try it & let me know (i've never done it but I think that's how you take them out)
Old Sep 10, 2004 | 11:11 AM
TK429x's Avatar
Guys,
I just repaired my heated seat switches. Thought you might like to hear how I did it. My problem was that the switches worked but the the lamp did not light up.
I replaced the burnt out lamp with one that I got from Radio Shack. It was a 12v 60 mA Micro Lamp #7219 part # 272-1092 package of 2 for $1.49 plus tax. This lamp is the same diameter as the OEM lamp, but just a little shorter ~1.5mm. Didn't know what the current rating of the OEM lamp was, because both of mine were shot.
To remove the switches, unbutton the emergency break handle boot. From here you should be able to reach back and just push the switches up and out. Unplug the switches and have something to tie the plugs to so you don't drop them back down into the console. Once you have the switch out you can check that it workes with a multimeter. Disassemble the switch with a flat screwdriver and replace the lamp. This should be pretty straight foward. A pick and small pair of needle nose pliers are helpful. Also, this is a lamp not a led so direction does not matter.
So far this is working for me. Let me know if you have any questions.
Jim
Old Sep 10, 2004 | 01:38 PM
RA030726's Avatar
ohh good to know radio shack has the right parts!
gavin68
Sep 18, 2021 12:36 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
