Need Help with trunk lock assembly
my trunk flaps open all the time cause the top part of the trunk lid which locks to the bottom is damaged. I finally got a new top part from nissan but the bottom part is messed up too. When u press the release button on the door or on my alarm it makes some slapping noise but doesnt do anything. The bottom part actually came loose before and i put it back but i saw some string with like a ball at the end and when i press the unlock it just like slaps around or something. Does anyone know how to fix the bottom part or what has to be done?
i know how the top part is done but i dont want to put the new piece on and take a chance of never being able to open the trunk unless by force.
thanks in advance
thanks in advance
The striker on the bottom part has a rubber washer. If that washer gets out of place you won't be able to open the trunk. If you can somehow open the trunk and look at the metal wire pulling back as someone pushes the opn button, you'll see what I mean.
looking but not seeing what u r talking about. You got a number or AIM i can talk to more directly with?
iight i see it, so the washer should be right behind the ball i guess. Gonna see if that works, thanks a mil
i f*cking locked the sh*t. I thought i did it right, when i pressed the button it even popped the lock but when i finally close it, it makes g@y sound and doesnt want to open up. I dont have key for trunk either. What are my options? besides forcing it open and wasting 30 bucks....
You can open it from inside. You'll have to take off the rear seats and all the plates behind the seats. It should take a while. I remember when it happened to me a few years back. It was a pain but I got it to work. I'll try to get a pick of where the washer should be.
The pic is upside down by the way. If you have a long piece of metal, rod or pipe, push the tab I mentioned up. I was just taking the pic and pushed it down and locked out my trunk. Pushed it back up and it works fine.
I tend to get a bit irritable
it is, i'm mad, depressed, hungry, and trying to fight multiple demons right now. Don, i'll hit u up on AIM or email when i get back. Dave, thanks for all your help, i'm in a rush but dont want u guys to think i'm not gracious for your involvement. i'll talk to all of u later. Peace
http://forums.maxima.org/showthread.php?t=254238&page=2
3rd post down
You don't need to take your seat or anything out, just use a flashlight and a long skinny tool. (broken mop handle)
3rd post down
well just a small update, i forced the trunk open and now when it closes there's like a small gap. Seems like body of car was pulled a little or something. I hate doing stuff myself cause things just always end up messing up. I have a sub box blocking the hole from inside car so i couldnt use a broom or anything to open trunk. I locked it again thinking i fixed the problem and this BS starts again so i just kept it locked for now. The bottom part has a lot of gooey stuff on it and makes the release kind of move in a funny way. I dont need access to my trunk until i get my new amp anyway so i'm just gonna ride it like that for time being. thanks Dave.
REDinLV
08-15-2024 12:30 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
atriuum
09-28-2015 01:19 PM
