DR causing my CEL
Old Aug 23, 2004 | 03:15 PM
bigleman's Avatar
Advocatus Diaboli
DR causing my CEL
Would the Drop Resistor mod cause CEL to come on? I know I still need to check the codes, but just as a quick refferance, would it cause it, and how do i need to do the mod so it doesnt trip the light?
Old Aug 23, 2004 | 03:18 PM
Kevlo911's Avatar
Kevlo for President
Yes, it will make CEL come on.
Old Aug 23, 2004 | 03:54 PM
nick's Avatar
you will get the 1205 code - line pressure solenoid
Nick.
Old Aug 23, 2004 | 05:49 PM
bigleman's Avatar
Advocatus Diaboli
i had it checked at auto zone just now, it was a 0745
Old Aug 23, 2004 | 06:09 PM
nostrixoxide's Avatar
bigleman,
Code P0745 is the same code as 1205. I placed the (P) infront of your code because it was pulled with a OBD2 scantool. When you use the scan tool there is a completely different set of numbers that have the same meaning as what you would get if you manulley pulled the codes from the computer.
There is currently no way to wire the DR mod so that the CEL will not come on for a 98 model year. Some of the earlier models have or don't have this problem. However we 98 owners just have to make sure to reset the CEL when it appears. If you do not know how to manuelly reset your CEL I suggest you read the Sticky's and learn how to do that. It sure is alot easier to do it yourself then have to go to autozone & what for the guy to do it for you.
jmlee44
Oct 2, 2022 02:13 PM
TKHanson
Nov 24, 2018 01:39 AM
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
