Some interior lights (LEDS) are out
Old Aug 23, 2004 | 04:33 PM
HarrisH's Avatar
My rear defrost LED, my cruise control LED, and my seatbelt light are out I'm not to good with electrical stuff, so is there any easy way to replace them? Thanks.
Old Aug 23, 2004 | 05:16 PM
XpLiCiT's Avatar
I also have this problem, with the addition of like 2 lights in my climate control system and 1/2 in my Bose HU... really ****es me off sometimes.
Old Aug 23, 2004 | 05:17 PM
Ant96GLE's Avatar
okay I've taken out the center dash before but I never noticed the bulbs so I cant answer that... however the seatbelt light inside the dash you have to take out the entire speedo/tachometer and the bulbs twist out, its pretty easy. You need to take out 2 screws under your steering column and remove the plastic cover on the steering column. Then unscrew 2 screws that are above the plastic cover over the speedo and take that moulding out. Then you can take out the 3 or 4 screws that hold in the entire speedo assembly... just remember theres a couple of plugs before you take it out and you can locate the bulb... before you take them out try to mark off which bulb is the seatbelt light.
Stupid question... did you put in LED's? OEM has bulbs...
MaxLife17
Jun 27, 2019 01:37 PM
minsbang
Sep 11, 2015 08:48 PM
MaxLife17
Sep 8, 2015 02:36 PM
jds22
Sep 4, 2015 01:52 PM
A32goldylocks
Sep 2, 2015 06:39 AM
