HELP with FSTB install
Old Aug 24, 2004 | 12:27 PM
soccstv's Avatar
I can't get the bolts off of the struts! I just tried spraying the bolts with wd 40, but they don't even budge. Is there a trick to getting them off? Did any of you have problems removing yours? Please help!
Old Aug 24, 2004 | 12:30 PM
s0ber's Avatar
heh, no mine were easy...
breaker bar? longer rachet, longer is better if u cant get it off!
happyricefob's Avatar
V^___^V
u need a torque wrench to help you remove those 6 14mm bolts. stock spec is 60lb/ft i believe. u should tighten the bolts with the FSTB at 30lb/ft.
Old Aug 24, 2004 | 12:32 PM
stang233's Avatar
Those should not be hard
Man those nuts should not be hard to get off. Be carefulll if you break off the bolts to your struts that will get very expensive. But really the only thing you can do is use a pry bar and hope to hell that they come.
Things to try:
1. WD-40(you said did)
2. Tapping with hammer, not to ruin sides of bolt, ie tap
3. Hope to hell the bolts dont break
4. Make sure you are loosening. counterclockwise
Sorry man not much else to tell you
Old Aug 24, 2004 | 12:34 PM
sunysb83's Avatar
ahh, i have the same problem too, i got a front strut bar last week but couldn't get the bolts off. i tried soaking it in oil, used ratchet, wrench, pliers, but it wouldn't budge also, still can't get it off
Old Aug 24, 2004 | 12:37 PM
stang233's Avatar
Not that wrench
If you read the instructions you are really never suppose to loosen things with torque wrenchs they are made for torqueing things down. If you loosen very tight bolts/nuts your wrench will become in accurate. Also be sure to always loosen the tention on your wrench when done with it.
V^___^V
Originally Posted by stang233
Well do not ever use his torque wrench. If you read the instructions you are really never suppose to loosen things with torque wrenchs they are made for torqueing things down..
OMG wtf are u talking about?
http://web.archive.org/web/200111210...eston/stb.html
Old Aug 24, 2004 | 12:45 PM
nadir_s's Avatar
vicodin ... gift of life
just make sure you don't strip it or it's goin to suck even more. I ended up needing an airtool to get my strut bolts off... at least 2 of em.
Get penetrating oil / wd40 and spray alot and let it sit for a day or a couple of hours.
Old Aug 24, 2004 | 12:46 PM
stang233's Avatar
Just from experience
Well those people dont buy the torque wrenches either. All i am saying is that you are not suppose to loosen very tight nuts/bolts with a torque wrench, it can stretch the metal inside the wrench and make the wrench torque Improperly when re-toruqeing things. Just something to thing about. Sorry to be so direct about it before I just want people to be aware of it. Dont want them screwing their cars up when trying to do things right with the torque wrench.
Old Aug 24, 2004 | 01:01 PM
Brudaddy's Avatar
Just get a breaker bar or some kind of extender for the socket.
Then, you should have not problem.
Torque is what you want on your side, and when you have a much longer bar to pull, it is easier.
Old Aug 24, 2004 | 01:18 PM
DAVE Sz's Avatar
Hooooooonda.....
Originally Posted by happyricefob
WTF are you talking about? A torque wrench is used to torque things not to loosen them. You will **** it up if you use it as a breaker bar.
Old Aug 24, 2004 | 01:22 PM
stang233's Avatar
Exactly
Dude calm down. Yeah that is what I am saying you will ruin it if you use it as a breaker bar. Its not a breaker bar its a torque wrench for tightening not loosening
Old Aug 24, 2004 | 01:30 PM
MadChef's Avatar
The nuts on my front strut brackets were really, really hard to get off.
Be more carefull than I was; if you turn them hard enough, you can actually twist the nut enough that you will never be able to wrench it off.
I ended up cutting the damn nut right off the bolt because it was so warped. A new upper strut mount bracket (called an insulator assembly or something similar, just a plate with three bolts on it) only costs around $30, but if you have to pay somebody to put it in, well, labor costs "more".
Old Aug 24, 2004 | 01:46 PM
lefty
how about taking it to a local garage with some air tools. Give the guy a couple of bucks to save you the trouble.
Old Aug 24, 2004 | 01:57 PM
PAREDLINE's Avatar
get a propane torch and heat the thing up. Heat for like 5 minutes and then if it doesnt come off you're SOL. Dont spray WD-40 before you heat it up. If you do it might catch fire.
I've never had this happen in my life. You must spray your engine compartment with water or something.
Old Aug 24, 2004 | 05:56 PM
soccstv's Avatar
Sorry I haven't replied back, just finished washing, claying, and waxing my car. Anyway, I finally got the bolts off. I stripped one of them really bad, but I got the local mechanic to get it off with his wrench. Right now, I have a regular 10-1.25 nut on there with 2 washers to replace the stripped nut, but I called nissan and ordered a new one. It'll be here on friday. Should i be ok without the stock nut?
Old Aug 24, 2004 | 05:59 PM
mansurxk's Avatar
yeah just take it easy with the car til you get that bolt in, you dont want it to get rippedoff on a tough turn
Old Aug 24, 2004 | 07:01 PM
Saddles's Avatar
breaker bar did it for...maybe try some pb blaster? oh yeah, dont break em off...the plates that go onhe top of the shocks are hella expensive. I ended up boring out a stud that was broken off and replacing it with a bolt...was slow work...
Old Aug 24, 2004 | 08:17 PM
Magikone69's Avatar
mine were very hard to get off also, i actually broke my socket wrench tryin to get it off, it was a cheapo wrench but it amazed me that it broke. i finally got them off with enough strength and wd40. i actually messed up a nut pretty bad as i was retightening it, its almost completely round. im going to install my new struts soon so i hope i can get it off.
i was using a lil hand wrench, im positive if i had a longer wrench i could got them off alot easier. invest in one.
Old Aug 25, 2004 | 01:55 AM
V^___^V
OMG u are such a . i use torque wrench to remove all my wheels lugs. i use torque wrench to remove my shocks assembly. i also use torque wrench to untighten/tighten other modifications as well. the only person who will **** it up is whoever doesn't know how to use a torque wrench.
okay whatever. use ur breaker bar or whatever wrench that u feel the best to mod ur car. at least when i use my torque wrench to untighten bolts i never stripped them. so whatever works the best for u works.
Old Aug 25, 2004 | 02:01 AM
DAVE Sz's Avatar
Hooooooonda.....
You obviously don't know how to use it. Either that or you're calling something else a torque wrench. In the end, yes you can use it. It's not what the TQ wrench was made for and it WILL shorten the tools lifespan and it WILL make the wrench less accurate. You may be thinking you're tightening it to 40ft/lbs when in reality it's 45ft/lbs. It's your choice.
Old Aug 25, 2004 | 04:12 AM
V^___^V
okay you're right. i'm wrong. you win.
Old Aug 25, 2004 | 05:18 AM
DAVE Sz's Avatar
Hooooooonda.....
This isn't some freaking competition. I just don't want others to get false info.
Old Aug 25, 2004 | 05:49 AM
Stephen Max's Avatar
You sure you're not talking about an impact wrench?
Dave Sz is right - you can ruin the calibration of a clicker type torque wrench if you use it for loosening. It will still work, but it may not give you the right torque when it clicks. Now the flex beam type of torque wrench you can use for whatever you want, as long as you don't bend the indicator rod.
Old Aug 25, 2004 | 05:55 AM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I hope your pride/ego doesn't prevent you from realizing that he is correct and you're wrong. If you need leverage you use a breaker bar like these: ,
or a "cheater bar" which basically is a long pipe you slip over the breaker bar for additional leverage. A torque wrench is a precision mechanism that helps you tighten things to the correct specification and thats it. You use it for any purpose other than that you will throw it off.
Since you've been working on your car this whole time loosening bolts w/ your torque wrench basically you have no idea if your torque wrench is clicking @ 60ft/lb even when you set it for 80ft/lb to tighten your lug nuts.
Old Aug 26, 2004 | 05:17 PM
nadir_s's Avatar
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
