Getting the clock bezel off
Old Aug 24, 2004 | 06:16 PM
vvslavavv's Avatar
I'm trying to get the clock bezel off. It's the piece that has the digital clock, an emergency turn signal button, and the rear defroster button. I'm trying to pull it off, but something is still holding it. What's the best way to get it off.
Old Aug 24, 2004 | 06:19 PM
guyincognito's Avatar
use a screwdriver and carefully pry it out, it is just held in by clips. You'll get it if you try hard enough, just be careful enough not to break anything
Old Aug 24, 2004 | 06:23 PM
vvslavavv's Avatar
All the way around the upper vents as well? Or is it two separate pieces?
Old Aug 24, 2004 | 06:27 PM
sunten1
yep its connected up to the vents one piece
Old Aug 24, 2004 | 06:58 PM
Keyser Skoze's Avatar
Just make shure that the vents dont fall apart because putting them together isnt fun.
Saddles's Avatar
pop each side out, and then put a screw driver in the middle top and pry out...careful, the vents are a ***** to get back in the bezel, and if you take the vents too far apart... ( yes all those little cross pieces are seperate ) its quite fun to put it all back together.
shilov
Feb 19, 2024 09:40 PM
t6378tp
Sep 29, 2018 04:27 PM
Matt93SE
Apr 8, 2018 09:23 AM
viperboy
Sep 27, 2015 07:05 PM
Violator
Sep 9, 2015 10:14 AM
