cel 0409
Old Aug 25, 2004 | 06:31 AM
sagamax's Avatar
Give me a Bud Light Holmes
cel 0409
ok this code is 02 sensor slow responce. this code is ****ing me off i replaced the o2 sensors and i still get the same code over and over. even when i reset the ecu it come back on. dont know what to do?????
Old Aug 25, 2004 | 10:10 AM
DAVE Sz's Avatar
Hooooooonda.....
You replaced the one further from the front of the car correct? Check for air leaks, aftermarket intake, or exhaust leaks.
Old Aug 25, 2004 | 11:56 AM
sagamax's Avatar
yup thats the one i replaced......this weekend i will take some seafoam and add it. ill look for smoke around the exhaust pipe too see if there is a leak
Old Aug 25, 2004 | 01:03 PM
cardana24's Avatar
Blown
I just posted about the exact same problem...I have replace the sensor twice...I am replacing the one on the rear branch of the Y closest to the fire wall....I guess I may do the sea foam thing as well to check for air leaks....mine will trip every thousand miles or so. I am really out of ideas. I also got the knock sensor code as well a while ago with this one, I repalced the KS and the 0409 still came back.
Old Aug 25, 2004 | 02:30 PM
sagamax's Avatar
well i am just getting this single code by it self no ks code. and also i havnt felt any power loss. actually when i replaced the last o2 sensor i felt a bit of a power increase so i highly doubt it is the ks.
does anybody else have a clue about this 0409 code
Old Aug 25, 2004 | 08:31 PM
sagamax's Avatar
well i got my obd2 scanner today and i checked the code and it ended up being p0153 which is 0413 on the cel method....i also checked the readings on the bank 1 sensor 1 and it was all screwed up so i think i found the cause of the cel but i dont know y the cel method was giving me 0409 instead of 0413....very weird hopefully when i change this sensor no more cel
Old Aug 26, 2004 | 05:09 AM
cardana24's Avatar
Blown
Please keep me posted on what you find out about when you change the other sensor.
Old Aug 26, 2004 | 07:02 AM
DAVE Sz's Avatar
Hooooooonda.....
Ok, PO153 is the left bank sensor, the one closer to the radiator.
Old Aug 26, 2004 | 07:34 AM
cardana24's Avatar
Blown
I guess I need to borrow or have autozone check my codes on a scanner...thats kinda messed up though that the ecu would throw the wrong code.
Old Aug 27, 2004 | 08:05 AM
sagamax's Avatar
added some seafoam today and no smoke by any of the exhaust pipes so i got no leaks. probably will order the new o2 sensor when i get my next paycheck. will keep u guys posted
Old Aug 27, 2004 | 08:45 AM
cardana24's Avatar
Blown
I will try to get my codes pulled this weekend with a scanner so we can find out if this is a common problem to get false reading using the CEL light.
Old Aug 27, 2004 | 12:07 PM
DAVE Sz's Avatar
Hooooooonda.....
The ECU will NOT throw a wrong code. Maybe when you replaced the O2 the other was too slow compared to the new one and that's why the CEL was thrown.
Old Aug 27, 2004 | 12:45 PM
cardana24's Avatar
Blown
I am not positive I understand that....If you put a new fully functional sensor in...why would it throw a code saying the rear bank is still screwed when in fact the problem is being generated in the front bank?
Old Aug 27, 2004 | 04:58 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I too have had this code pop up, SES light stays on for a week or so, shuts itself on its own and sometimes repeats until another month .. I remember someone mentioning this o2 sensor is near the cat converter area, or is it somewhere else?
Old Aug 27, 2004 | 05:19 PM
Kevlo911's Avatar
Kevlo for President
Maybe the harness is bad.
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
