E-brake light
Old Aug 25, 2004 | 07:36 AM
Larry H's Avatar
E-brake light
Hi guys,
any 4th gens have a problem with their e-brake light? mine goes off after I release the e-brake like it should. but when I start driving, it comes back on after about 5 minutes. then it'll either stay on or sometimes it goes out by itself.
I don't think my caliper is stuck since the car rolls really easily backward at a light, no groaning sounds at 5mph, etc.
any advice is greatly appreciated.
Larry
Old Aug 25, 2004 | 07:40 AM
PAREDLINE's Avatar
you might have a bad E-brake light switch. Next time that happens pull the break up and down and see if it goes away.
Once my master cylinder broke on my 91SE (only 2 wheels were stopping) and the brake light was on for a week. Then I lost pedal pressure and realized something was wrong.
If you can put your car up on a lift or jack up all 4 wheels have someone push the brake pedal and see if all 4 wheels are braking.
I know if your brake fluid is low the e-brake light will come on. Check fluid too.
Old Aug 25, 2004 | 10:24 AM
Brudaddy's Avatar
Yeah, I would definitely check this out.
Old Aug 25, 2004 | 12:38 PM
naijai's Avatar
Yur fluid is low check check
Old Aug 25, 2004 | 12:54 PM
Larry H's Avatar
thanks guys. I'll check it tonight.
Old Aug 25, 2004 | 01:01 PM
|Bijan|'s Avatar
UCF Lexus
No.......go check now!
What are you doing? GO GO GO GO!
Old Aug 26, 2004 | 07:33 AM
Larry H's Avatar
haha...
I take the subway to work, so my max is a weekend driver.
I appreciate your concern for my well-being.
Old Aug 26, 2004 | 09:24 AM
njmodi's Avatar
Do I get a tax break?
BTW, if your fluid does end up being low, that is typically a sign that your pads are worn (front or rear or both). Before you top off the fluid, check the pads first - if you do install new pads, the fluid level will rise as you retract the caliper pistons.... so you may not need to top it off in that case...
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
