My car wiggles around constantly
Why are you assuming that the springs caused your bad ride and handling? Ride will suffer a little with any lowering spring compared to stock cushiness, but handling should definitely IMPROVE.
The causes for your crappy ride as I see it are:
1. Tokico Blues aren't better than stock and you should have had Illuminas or Konis paired with lowering springs to maintain ride.
2. You needed new strut mounts and bump stops.
3. I've never heard of Suspension Techniques springs so they may not be matched/tuned as well as a higher quality spring. This does not mean that a spring that drops 1.5" will necessarily give a bad ride or handling.
All I want out of the Maxima is forgiveness over bumps and smooth, predictable response on the highway. Putting the SE springs has it tracking a straight line again, and hopefully abusing my tires a lot less. We'll see how it goes.
Dave
Originally Posted by dgeesaman
Tokico Blues, as I understand it, are very similar to stock. I never said they were 'better'. They were chosen because they were a cheaper alternative to OEM replacements.
Macpherson struts aren't the best but they're respectable. Same goes for the beam.
alixc
Aug 11, 2020 01:48 PM
Lakersallday24
Jun 16, 2019 01:35 AM
