ugh, i hate my tranny
Old Aug 29, 2004 | 09:13 AM
nadir_s's Avatar
vicodin ... gift of life
Last summer, I had my tranny rebuilt because my differential bearings went back. At the same time, I had 3rd and 4th gear replaced. The shop must have done a ****ty job because 9 months later, i noticed the tranny starting to leak....
I don't hear the bearings whining in gear, but I can only hope...
warranty expired too when I hit 12k miles. so frustrating!
IF, sometime down the road, my tranny does start crapping out me, I can swap in a 5th gen tranny in, without much modification, right? I want to avoid 4th gen trannies now
Old Aug 29, 2004 | 09:41 AM
thisisausername's Avatar
you messed up a 5 spd at 12k miles????? Mine runs just fine at 117k.
Old Aug 29, 2004 | 10:27 AM
liqidvenom's Avatar
brotherhood of tq
i say u swap in the 5 sp one form a 5th gen.. works great
Old Aug 29, 2004 | 10:52 AM
Kevlo911's Avatar
Kevlo for President
It fits right in, the shifter will sit a little further bakc.
Old Aug 29, 2004 | 10:59 AM
|Bijan|'s Avatar
UCF Lexus
On my 5th gen tranny........(auto) the only thing different is one set of 6 wires that we soldered the 4th gen harness to.
Old Aug 29, 2004 | 11:16 AM
nadir_s's Avatar
i didn't mess up a tranny in 12k miles. If you look up the differential bearings problem on the 5-spds, you'd know what I'm talking about.
But seriously, i'm glad to know that the 5th gen 5-spd will bolt up. Thanks guys, i'll end up doing that for sure if this thing craps out on me... or just sell the car.
Old Aug 29, 2004 | 11:42 AM
|Bijan|'s Avatar
UCF Lexus
Nadir.....dont get too excited YET. The member luckee2behere has a 97....and he put a 5spd 5th gen in his....but he had to get 5th axles. I however didnt have to....4th gen axles slid right in. So...be careful on that.
Old Aug 29, 2004 | 11:56 AM
Kevlo911's Avatar
Kevlo for President
Actually, everyone thought you had to get hte 5th gen axles, but there a few people running 4th gen axles with the 5th gen tranny.
Old Aug 29, 2004 | 12:02 PM
Nismo3112's Avatar
Custom User Title
I'm also going for a 5th gen tranny if mine craps out. (Just did a 5spd conversion)
Old Aug 29, 2004 | 12:10 PM
Terran's Avatar
I'm in the process of doing this now. We would have been done today, but the damn dealer didn't tell me I'd need another gasket when I bought the rear main seal to replace mine that was leaking. Here's a thread I started and it answered all the questions I had http://forums.maxima.org/showthread.php?t=325741.
Old Aug 29, 2004 | 12:22 PM
ABK's Avatar
ABK
they prolly didn't seal the bellhousing to the tranny case right or something. Check where you are leaking from. Put some die into the motor and see maybe you are leaking from rear main seal. Also check your axle seals on the tranny. It will really suck if you tranny seizes up on you and sends you spinning. At least refill it.
Old Aug 29, 2004 | 12:29 PM
|Bijan|'s Avatar
UCF Lexus
kevlo - I dunno why some fit, and other dont
Old Aug 29, 2004 | 12:40 PM
Kevlo911's Avatar
Kevlo for President
I think they all fit, it is just everyone did not try it.
Old Aug 29, 2004 | 04:28 PM
Maximus_95's Avatar
i hate my tranny too. got it rebuilt like 4 months ago and its giving me a hard time.
the shifter does not go back to the middle.
its really hard getting it from 2nd gear to 3rd. i just had to get used to it.
and plus, sometimes, when going over a speedbump on 1st gear, i would slow down, and still hold it in 1st with my clutch all the way down, and when i try to take off again, i notice that it had popped out of first. i hate my tranny!!!
Old Aug 30, 2004 | 05:27 AM
naijai's Avatar
Ok i wanna know any modifications are needed to put a 5th gen tranny in a 4th gen and is there a write up on this
Old Aug 30, 2004 | 06:03 AM
Stephen Max's Avatar
No need to worry just yet, unless the leaking is really bad. Do you know where it is leaking? Even if it is leaking a bit around the drive shaft seals, that doesn't mean the diffy bearings are bad, especially if you don't have any gear whine. It's normal for seals to leak a little bit over time, no seal on an engine is absolutely perfect.
Old Aug 30, 2004 | 07:31 AM
I30tMikeD's Avatar
Nadir, I have the same fear as you. No leaking for me yet and it's been 16K miles since the rebuild. Reading motorvate site always get me thinking that the shop I used may not have fixed the problem but just replaced the shims with the same size they took out. As much as I explained the problem to them, who knows if they did it right. Only time will tell.
I had bad bearings for a long, long time and did not get the whine. Well, maybe a tad at the very end but it was hardly noticeable.
Old Aug 30, 2004 | 09:37 AM
DAVE Sz's Avatar
Hooooooonda.....
I'm pretty sure that if you get the 2k1 LSD trans you'll need a new axle or new axles.
Old Aug 30, 2004 | 01:20 PM
Kevlo911's Avatar
Kevlo for President
if you get hte LSD one you have to get the passenger side axle. Regular tranny you don't need axles.
TKHanson
Nov 24, 2018 01:39 AM
doctorpullit
Dec 12, 2015 09:39 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
