Strange short somewhere
Old Aug 29, 2004 | 02:41 PM
Liquid_pjear's Avatar
I parked my maxima a few months ago and began working on it, I went to take it on spin the other night and it all of a sudden wont start. Everything kicks on like it is going to start but nothing happens. The real ***** is when I hooked it up to my jeep to jump it it started just fine. So I have a short somewhere, I figured maybe it is a ground but they seem to be intact. I am waiting for my buddy to come over with his multimeter next weekend but until then any ideas of places that have failed for you guys before.
Old Aug 29, 2004 | 02:51 PM
nostrixoxide's Avatar
Do you think that the battery just drained from sitting for serveral month's? That would be my guess. Especially if you were able to jump start it. If a battery sit's to long it will die, even worse it can kill a cell so it won't hold a charge at all. What makes you think there is a short in the electrical system?
Old Aug 29, 2004 | 03:00 PM
The battery is brand new. And the car has power just fine the fuel pump kicks on the starter clicks on all is good the car just wont start as soon as i hook it up to the jeep it starts no problem. It has to be a short.
Old Aug 29, 2004 | 04:02 PM
Sorry it took me so long to reply back. I was reading my manuel to see if there was any info in there that could help. First off what kind of repairs were you making to the max in it's down time?
From what I was reading & your symptoms it seems like your having a voltage issue. That would explain why when you get a jump start the vehicle is able to start. You are deffinitly better off waiting until you have a multimeter to run a few test before you start replacing anything. I'm not so sure that it's a grounding issue, because you mentioned you have lights, power etc. My guess is maybe the voltage regulator on the back of the altinator or maybe a faulty starter solenoid. Do you have a Haynes manuel? If not I suggest picking one up & running a few of the diagnostic test they recommend to check for faulty parts or circuits.
Old Aug 30, 2004 | 04:26 PM
Well I appreciate the reply. I am going to have to wait for the multi meter unless someone has had a similar situation and can offer advice. I hate having to track down electrical issues. I hope it is just a lose connection or damaged wire. Ohh and it was parked for transmission work as well as some interior stuff. I am still working on it.
Old Aug 30, 2004 | 04:35 PM
No problem, I hope you can get it resolved. Once you do figure it out, please post the cure so well have one more solution located on the org. Take care!!!
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
