Why is 1995 so fast?
Old Aug 31, 2004 | 02:15 PM
Maxima lover
From what I have read on the internet the average 1995 Maxima SE 5 speed does 0-60 in about 6.6sec. and the 1/4 mile in about 15.2secs. My dad has the 3.5L 2002 Maxima SE auto and it does about the same numbers probably a little slower from 0-60. My question is how can the 3.0L 1995 Maxima making about 190HP keep up and possibly beat the 3.5L 2002 Maxima making 255HP? I know one is a manual and one is an auto which could make a difference but its not enough to make up 65HP. Do the cars weigh that much different? Also if anyone has driven both could you tell which one had more low, middle, and high end power or did they feel about the same?
Old Aug 31, 2004 | 02:21 PM
NmexMAX's Avatar
dot dot dot ...
Weight differences, and I've also heard some people talk about more emmisions restrictions, but they (VQ) are rated at 190hp from 95-99, but for some reason the 95 seems to be faster.
Could be:::
Wheels, 15's vs. 16's and some minor body weight differences.
Old Aug 31, 2004 | 02:22 PM
Vaudeville Villain's Avatar
6.6 is pretty impressive for a 4th gen (talk about beatin' on your car). Sure, 4th gens have a weight advantage - but I'd guess the biggest factor is traction. I've driven tons of 5th and 6th gens (ahh, the benefits of being a valet) and is usually seems like there's simply too much power to get it all down in first gear. I'd compare it to, say, a 1.8T VW GTI, which struggle to put the boost to use in first gear.
In my experience, 5th gens whoop up on my 98 SE 5-speed, and the difference is VERY evident by the time you're finishing second gear and heading through third. Just my two cents ...
Old Aug 31, 2004 | 02:27 PM
NmexMAX's Avatar
dot dot dot ...
5.5 Gens will put a beating, but not 00-01. They have a power/weight disadvantage, but mod 'em both and you got a good match up.
Old Aug 31, 2004 | 02:28 PM
Entropy's Avatar
1995 Nissan Maxima SE Curb Weight = 3001 lbs
2002 Nissan Maxima SE Curb Weight = 3224 lbs
Old Aug 31, 2004 | 02:32 PM
Originally Posted by NmexMAX
5.5 Gens will put a beating ...
Good eye ... 5.5gen, to be exact.
MattMaxima_V2's Avatar
It has to do with Rim size, tire size, the driver itself, but mostly it goes by wheel & tire size. The 95 Maxima uses 15 inch wheels. Where as a 2k2 uses 17 inch wheels. smaller the faster you accelerate. Under shop talk and reading room there is an articale. When the module is up you'll be able to read it. Very interesting
MaximaSE96's Avatar
Maxima Owner
partly emissions and weight 95 were non OBD II and 4th gens in general are kwiker from stop than later
Old Aug 31, 2004 | 02:35 PM
NmexMAX's Avatar
dot dot dot ...
ALL 4th gen Maximas are OBD II ALL........ALL
Old Aug 31, 2004 | 02:38 PM
Um, that's incorrect. 1999 was the intro of OBDII, if I'm not mistaken.
Old Aug 31, 2004 | 02:40 PM
happyricefob's Avatar
V^___^V
ugh...no. i'm OBD 1
Old Aug 31, 2004 | 02:42 PM
Brudaddy's Avatar
6.6 0-60mph is not all that impressive for a maxima.
Mine is quicker than that.
I did the quarter mile in 15.1 and there are plenty faster than me.
I know a guy that did 14.78 stock with a 5spd like mine.
Anyway, if the 3.5 is driven correctly, it should beat the 4th gen...if they are modded the same.
However, the rating of the 190hp is clearly underrated based on how the car moves in reality. Wouldn't you say so?
Old Aug 31, 2004 | 02:45 PM
MaximaSE96's Avatar
Maxima Owner
95 are OBD I
Old Aug 31, 2004 | 02:47 PM
MaximaSE96's Avatar
Maxima Owner
do u have an OBD II Port or Nissan Diagnostic port i bet u have the Nissan Port
Old Aug 31, 2004 | 02:48 PM
V^___^V
1995 = Obd 1
1996-1999 = Obd 2
Old Aug 31, 2004 | 03:04 PM
Originally Posted by happyricefob
1995 = Obd 1
1996-1999 = Obd 2
If this is true, answer me this: Stillen offers two models for their 4th gen supercharger. One is for 95-98, the other is for only the 99. Isn't the introduction of OBDII the reason for this?
Old Aug 31, 2004 | 03:05 PM
Ant96GLE's Avatar
huh? a 5.5 will eat your 95 alive even if its auto and your 5 speed
Old Aug 31, 2004 | 03:08 PM
I usually run 0-60 within a tenth of 7.0sec ... but I never dump my clutch or rev the **** out of it. I'm stock, btw. But there are plenty of factors that can alter this. And yes, I agree the 190 rating doesn't match how the car drives and feels ... but I'd say it's the 222lb.ft. that make it seem that way
Old Aug 31, 2004 | 03:17 PM
bruteMax's Avatar
gawd, so much misinformation on the 4th gen forum.
1st: 1996 was the first year of mandatory obd-ii compliance in north america. This does not mean manufacturers couldn't introduce the standard earlier. Thus:
2nd: 1995 Maximas are obd-ii. Thus:
3rd: my Autotap obd-ii scanner works just fine...
Old Aug 31, 2004 | 03:21 PM
MidwestMaX1's Avatar
222 lb feet? More like 205.
sunysb83's Avatar
what do u mean by underrated? do you mean that the 4th gen feels faster than 190 hp?
Old Aug 31, 2004 | 03:26 PM
Maxima lover
How fast do you think a 2002 auto is from 0-60 and in the 1/4 mile?
I cant see its much faster then 6.6 and 15.1
Old Aug 31, 2004 | 03:28 PM
mzmtg's Avatar
Minister of Silly Walks
The ignorance in this thread is staggering.
Take a look at timeslips that have been posted. The fastest 4th Gens around, by actual numbers, are 1997 models.
I have personally witnessed a 2k2 GLE (automatic, duh) run 14.3 with half a tank of gas, intkae and cat back. You'll never see a 4th gen with similar mods come anywhere near that.
1995s are NOT faster in general, everyone needs to get this BS out of their heads.
Old Aug 31, 2004 | 03:32 PM
nitromax's Avatar
reading HAYNES now, and it's says '95 & later are equipped with OBD-ll system. although i have been told at autozone that it didn't have it, I found the obd-ll connector and got codes and reset ecu through it.
Old Aug 31, 2004 | 03:33 PM
mzmtg's Avatar
Found it:
http://forums.maxima.org/showthread.php?t=130567
Old Aug 31, 2004 | 03:39 PM
Whoops ... 205 is correct.
Old Aug 31, 2004 | 03:46 PM
Maxima lover
Accually im almost positive the stock 1995-1996 GXE 5 Speed is the fastest of the 4th generation Maximas.
mzmtg do you have any numbers from a stock 5.5 gen. auto?
Old Aug 31, 2004 | 03:47 PM
Well strip me naked and call me hung ... I was told by a Stillen employee (for god's sake) that the 2 s/c models were due to the addition of OBDII in 1999!!! I figured his word was trustworthy .... maybe the fcukin UPS guy picked up the phone that day.
Old Aug 31, 2004 | 03:50 PM
Kevlo911's Avatar
Kevlo for President
Also, the 4th gen VQ is not underrated, just look at hte dynos.
Old Aug 31, 2004 | 04:08 PM
Maximus_95's Avatar
i would say weight, or even the 95 driver must have the cleanest launch.
Old Aug 31, 2004 | 04:15 PM
Maxima lover
200-250lbs makes up for 65 HP and 40lbs of torque?
200lbs cant affect a car more then .2-.3 seconds in the 1/4 mile, can it?
Old Aug 31, 2004 | 04:20 PM
mzmtg's Avatar
You got timeslips to back that up?
Old Aug 31, 2004 | 04:29 PM
NmexMAX's Avatar
dot dot dot ...
Back in the early days, there was a white 96 5spd JWT chip, POP and other misc stuff and he ran a 14.3, with the timeslip, and shortly after he bought a Black 2k or 2k1. And another, not stock of course black '97 ran the same, 14.3, with a video of it. This is the guy that did the Audi headlights later on. Keep in mind these aren't stock #'s
The website for the white 96 was how I got introduced to the org. Some guy shared a website for his integra and max, it was integr.vtec.net/geeser/maxima some shyt like that.
Those are the olny 2 at the time that ran low 14's w/o a VI. And there was that controversial guy that had a Rosewood 96 and did some "mods" to it that was running a 14.2 or so at the time, but never had timeslips to prove it.
Maxima lover
No, I don't but I have heard that on the org before. Also the 1995-1996 GXE 5 speed is the lightest 4th generation Maxima. So unless there is some other major performance difference that comes stock in the 1997-1999, the 1995-1996 should be faster.
Old Aug 31, 2004 | 04:54 PM
mzmtg's Avatar
Well, can't argue with that...
Old Aug 31, 2004 | 05:33 PM
Maxima lover
I would try to find the posts about it but that would take me hours that i dont want to spend. But it doesnt sound like you can argue about the weight difference which makes the 1995-1996 faster or maybe you just forgot to quote my whole statement when you said can't argue with that.
Mishmosh's Avatar
I think all the 4th gens are all comparable. I don't think anyone has shown one being faster than another although you can make an argument for it. And I believe Dave B put to rest that ALL MY1995 Maxima's are OBDII... finding out that one of the earliest made (in 1994) was OBDII. My 1995 Max is definitely OBDII.
Old Aug 31, 2004 | 07:02 PM
kenji's Avatar
Ha!
Neat, good for all of you who have OBDII 95's .. I have a 95 which is ABSOLUTELY NOT OBDII.
But if anyone wants to argue, it doesn't matter because I won't be able to convince you anyways (since you already know you are right)
Btw if anyone has an OBDII scanner and would like to try it on my car, humor me, because I've tried many of them.
Oh and I have personally read in OBDII manuals that many cars didn't adapt it until 1996. I/E If you goto Autozone and look it up in their OBDII manual, it will say Nissan Maxima 1996 up
But I'm sure someone is going to tell me that I don't know my car or that I'm dumb, so go ahead.
Old Aug 31, 2004 | 07:06 PM
kenji's Avatar
BTW, I'm not saying that anyone who has an OBDII 95 is lieing, in fact IIRC there were different ECU's with different productions of the car. (mine was made in 1994)
Old Aug 31, 2004 | 07:10 PM
ABK's Avatar
ABK
all 95's are OBD II, if you look you can't find the obd II plug anywhere but it's underneath the glow box.
obdI vq is a myth. I think nissan changed all their car over here to obd II since 95, because of the body change, and upcoming regulations.
