Timing chain tensioner on '98 SE
Old Sep 2, 2004 | 10:55 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I was advised by the dealer that my timing chain tensioner is probably going, which is causing the knocking sound during idle, just wondering to those who did have it replaced, how much did it cost for the whole repair?
Old Sep 2, 2004 | 02:21 PM
Kevlo911's Avatar
Kevlo for President
200, don't pay more.
Old Sep 2, 2004 | 02:57 PM
f550maranello2's Avatar
yea man repair that as soon as possible if the chain slips ur in BIG trouble and big repairs
Old Sep 2, 2004 | 06:50 PM
interesting, I read the TSB and this was common for '95-'96 Max's, but this seems rare for a '98 Max
I'm just wondering what else, besides mileage, would either make the tensioner go bad or cause something wrong in the timing chain area?
Old Sep 2, 2004 | 07:18 PM
PLUMMAXSE's Avatar
Is is knocking when it's warm?
Old Sep 3, 2004 | 10:53 AM
knocks when warm, but on cold startups it sounds like a fast knock for a second or 2, goes away during warmup, then comes back when fully warmed up at idle .. the car has been recently tuned, I always use premium and only premium gas, and the belts have been replaced. When I took it in for maintenance yesterday to have them check the knock, I was advised the sound was coming from the timing chain area so I'm hoping its something as simple as a tensioner worn out
Old Sep 3, 2004 | 01:26 PM
jbreit's Avatar
make sure you are using a quality oil filter and the proper weight oil for your climate....cheap filters can cause the rattle at start-up. Synthetic oil may help the rattle.....these are all free compared to the money you are looking at for a dealer to do it.
Regardless, for a 97 and newer max to rattle while warming is somethign i have not heard of. the chain would have a hard time jumping sprockets with the number of guides in place inside. The tensioner is a $50 part and can probably be done in less than 2 hours...i think the PS belt is in the way...and thats a pain to remove/replace.
Old Sep 3, 2004 | 02:30 PM
PLUMMAXSE's Avatar
Yeah, sounds like the correct call on the timimg chain tensioner. Mike knocks whenit's cold, but not when it warms up. Good luck !!
Old Sep 24, 2004 | 11:19 AM
I had a ? on part #'s
on Jerry Rome's site, it lists these part #'s for the tensioner. It seems like there's more than 1 tensioner for the timing chain, is that correct? And which part # would I need to order?
TENSIONER ASSEMBLY
Add to Cart Application Part number List Price Our Price View Item
Add Rear, Right 13070AL510 $66.53 $57.88 30
Add Upper, Rear, Right 13070AL510 $66.53 $57.88 30
Add V6, O.H.C.- DOHC, Rear, Right 13070AL510 $66.53 $57.88 30
Add Lower 1307031U03 $66.53 $57.88 30
Add V6, O.H.C.- DOHC, Front 1307031U03 $66.53 $57.88 30
Add Rear, Left 13070AL515 $66.53 $57.88 30
Add Upper, Front, Left 13070AL515 $66.53 $57.88 30
Add V6, O.H.C.- DOHC, Rear, Left 13070AL515 $66.53 $57.88 30
Old Sep 24, 2004 | 01:12 PM
ukmastermind's Avatar
$200 to repair the tensioners!? from what others have said this job takes like 6.5hrs...?
Old Sep 24, 2004 | 01:36 PM
Kevlo911's Avatar
Kevlo for President
Look in hte howtos for hte link to change the tensioner. It has the part numbers in there. Should not take more than 2 hours.
Old Sep 24, 2004 | 01:56 PM
this is currently being discussed under posting " Funny noise on cold start up 95 SE auto ( 1 2 )
nissanguy8 "
check it out
Old Sep 24, 2004 | 02:04 PM
just checked out the how to's...could not find anything on timing chains or tensioners...is the link still there..thanks LOTS
Old Sep 24, 2004 | 02:12 PM
Kevlo911's Avatar
Kevlo for President
Opps, I guess the link got deleted, now take a look.
http://forums.maxima.org/showthread....t=timing+chain
Old Sep 24, 2004 | 07:34 PM
nissanguy8's Avatar
WHo deleted my link!!!!!!!!!!!!!!!!!!!!!?????? Yea if someone said they could fix my timing chain tensioner with a new one for $200, it would have been done yesterday!! There are 2 on our cars I think. Let me know the follow up if you do get it fixed, I have traced the start up noise to the starter, so hopefully its not the chain tensioners!
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
