Split Second Belt Squeal Upon Start-Up
Old Sep 4, 2004 | 07:53 PM
MaximusAureleas's Avatar
There is a split-second squeal coming from the serpentine belt most everytime that I start my Max. No other noise what so ever though. Seems to be coming from the pulley directley under that adjustment bolt thingy. Anything I can do about it? Thanks.
Old Sep 4, 2004 | 08:20 PM
JSMax's Avatar
Sold
I had the same problem with mine, adjust the tension on the belt and all should be good. You should just have to loosen it a little bit. check your haynes manual (or other) for the proper amount of belt deflection.
Hope that helps
take care.
Old Sep 4, 2004 | 09:07 PM
I havent gotten around to getting a manual yet... I losen the tensioner bolt on my pulley right? We do belts at my work (jiffy lube), but I havent really touched one, ill have them take a look at it tommorow. Thanks.
Old Sep 4, 2004 | 09:11 PM
Tyrexx's Avatar
loosen ?
Old Sep 5, 2004 | 05:36 AM
Corey_25's Avatar
what year is your car and what mileage? It could still have original belts and may need replacing.
Old Sep 5, 2004 | 05:54 AM
davey6693's Avatar
Originally Posted by Tyrexx
loosen ?
Hmm... that's what I thought. A loose belt is going to make that noise - a belt that is on too tight will just wear earlier.
Old Sep 5, 2004 | 06:00 AM
a_prince1's Avatar
1. loosen idler pulley bolt
2. tighten belt tensioner (appropriately)
3. tighten idler pulley bolt
05' MaximaMan
Oct 8, 2017 06:36 PM
markevans999
Oct 25, 2015 08:27 AM
sliptap
Sep 30, 2015 05:57 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
