Driver Side Window
Old Sep 9, 2004 | 06:47 AM
grahamfsw's Avatar
Driver Side Window
Hey Everyone-
I just bought a '98 Maxima SE 5spd and had a quick question about a problem I discovered. My driver side window does not roll down all the way. Every other window in the car will roll down all the way. It rolls down with about 2 inches showing. Is this something I could possibly fix? Has anyone here experienced this problem before? How much would it cost to fix if I took it to a mechanic? Thanks for all the help!
-Graham
Old Sep 9, 2004 | 08:13 AM
Micah95GLE's Avatar
I haven't heard of that happening, but I suggest that you take the door panel off and see if something is blocking the window. That's what I would do. Maybe aftermarket speakers were installed that are too deep, or one of those styrofoam blocks inside might have fallen into the path of the window. Also, check the rails that the window slides through for any irregularities.
Old Sep 9, 2004 | 09:34 AM
OneToughMax's Avatar
even the rear windows?
Old Sep 9, 2004 | 09:48 AM
Taken2DaMax's Avatar
I think that he meant "every window other than the driver's side window rolls down"
First of all, does the motor still make noise like it's still working? If so, do what Micah said just open the door panel to see if their is any debris in the way of the window. The motor works but there is something blocking the way. Good Luck
Old Sep 9, 2004 | 10:02 AM
i used to have a civic, and my passenger window used to stop about half way down. it turns out it was just a tiny rock in the track that was stopping it. i cleaned it up and regreased it and everything was good to go...
Old Sep 9, 2004 | 04:36 PM
99se5spd's Avatar
take off the door panel, its a piece of styrofoam that was glued to the backside of the door panel, it fell off and into the door. happened to me.
boomerbrian
Oct 31, 2018 10:25 AM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
