rough idle STILL!!!!
Old Sep 18, 2004 | 09:38 AM
jaykid806's Avatar
my 99 max is still rough idle after a air idle control cleaning, throttle body cleaning and two new o2 sensors? could i need a new air idle thing whats goin on please help me?
Old Sep 18, 2004 | 10:00 AM
|Bijan|'s Avatar
UCF Lexus
adjust your idle speed
Old Sep 18, 2004 | 10:03 AM
acj's Avatar
acj
I know you said that it has a rough "idle", but just to make sure, does it smooth out as you give it a little gas?
Old Sep 18, 2004 | 10:10 AM
matty's Avatar
Is is a rough "idle" or does the idle just do a fluctuating thing ??
Did you over-rev your engine at all ?? possibly miss a shift and it shot past redline ??
-matt
Old Sep 18, 2004 | 10:15 AM
jaykid806's Avatar
idle was adjusted and when i come to a stop light it starts to fluctuate and go up and down, and kind of wants to take off.
Old Sep 18, 2004 | 07:15 PM
jaykid806's Avatar
i drove it tonite and it was fine, then on the way home it starts sputtering again, i startin to think i should trade it in for somethin with less problems
Old Sep 18, 2004 | 07:22 PM
ac465's Avatar
fuel injectors maybe
i kinda had the similar prob with my 95 max, wen idle it sputters, turns out the injectors were real dirty, could be that
Old Sep 18, 2004 | 07:26 PM
jaykid806's Avatar
what stuff should i run threw my car for injectors, i ran slick50 hi-mileage fuel system stuff threw is that good enough?
Old Sep 18, 2004 | 07:55 PM
jaykid806's Avatar
the mechanic i went to charged me $100 to clean and put back iac and car still runs like crap(rough idle) i feel like an idiot now im back to square one again!!!!!!!!!
Old Sep 18, 2004 | 08:09 PM
XeroX's Avatar
Hella internets
is this a good reference to seafoam?
Old Sep 18, 2004 | 10:24 PM
matty's Avatar
Check your Throttle Position Sensoor...I garentee its that
-matt
Old Sep 19, 2004 | 12:44 AM
guido32's Avatar
Could the TPS malfunctioning be causing my throttle to be jerky. When I am driving and I let off the throttle(slowly or abruptly), the car jerks badly. The same problem happens when I slowly accelerate while coasting. When applying throttle, acceleration isn't smooth. The engine seems to stumble and then all of a sudden the car jerks and then accelerates smoothly.
Old Sep 19, 2004 | 11:19 AM
jaykid806's Avatar
same with me, the tps is clean it took it apart and was very clean, idk and its drivin me crazy
Old Sep 19, 2004 | 11:49 AM
matty's Avatar
I dont think the TPS can be cleaned ??
-matt
Old Sep 19, 2004 | 12:02 PM
mansurxk's Avatar
yeah you cant clean the TPS, you can adjust it, i think jaykid is under the impression that the throttle body is the TPS, but its not, check your haynes manual on how to adjusting and checking with a multimeter
Old Sep 19, 2004 | 06:02 PM
jaykid806's Avatar
no i didn't clean the tps i was clean when i took it apart, and i know the difference between the tps and the throttle body! should i have the tps replaced if so how much does it cost? the part?
Old Sep 19, 2004 | 06:03 PM
matty's Avatar
TPS=Throttle Position Sensor....TPS's are alittle over $100
-matt
Old Sep 19, 2004 | 06:21 PM
jaykid806's Avatar
how do i adjust the tps if i can. when i took it apart the other day it looked pretty clean but who knows! thanks
Old Sep 19, 2004 | 07:42 PM
jaykid806's Avatar
bump........
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
