Getting Catless exhaust soon....
Old Sep 20, 2004 | 09:28 PM
Maxima Mike
I know I'll have a CEL, how would I get rid of it? What tool do I need in order to bypass the code? I'm going to have a local shop do this for me because I don't have time on the weekends to get anything installed. Thanks.
Old Sep 20, 2004 | 11:48 PM
nostrixoxide's Avatar
I don't think the 1hp gain & CEL is worth not running a cat? Just my 2 pennies.
To answer you question I've never heard of anything that can bypass the CEL light thrown from not running a cat. Your best bet is to just remove the bulb from behind the instrument cluster so the CEL indicator doesn't light up.
Old Sep 21, 2004 | 12:37 AM
Maxima Mike
Ah poop. Really? I read that thing in the Mod FAQ, and it seems like I should just cancel the order. What about the Y-pipe/Cat-back system? Will I have a CEL with that?
Old Sep 21, 2004 | 12:46 AM
happyricefob's Avatar
V^___^V
stay with stock cat please
Old Sep 21, 2004 | 01:07 AM
Maxima Mike
k, will do. I'll call warpspeed tomorrow and tell them to cancel the order.
Oh yeah, will I get a CEL with the Y-pipe and cat-back?
Old Sep 21, 2004 | 01:26 AM
No you will not
Old Sep 21, 2004 | 01:34 AM
Maxima Mike
Sweetness. Thanks for the help guys.
Old Sep 21, 2004 | 07:46 AM
MaxSpeedSE's Avatar
From what i understand is the sensor is after the cat. if your run a stright pipe, you will not have a check engion light
Old Sep 21, 2004 | 09:02 AM
Kevlo911's Avatar
Kevlo for President
Ya, but with no cat, the exhaust will smell and you gain MAYBE 1hp.
Old Sep 21, 2004 | 09:24 AM
MaxSpeedSE's Avatar
Well i have forced induction thats why im considering it, id see a little more then that.
Old Sep 21, 2004 | 09:32 AM
Nealoc187's Avatar
SLOW
yeah unless you are boosted there is really no reason to run a catless exhaust. i myself have a test pipe (no cat) and noticed absolutely no difference with it. if i knew where my stock cat was I'd put it back on.
Old Sep 21, 2004 | 11:06 AM
SupermaxGxe's Avatar
I have a resonator and no CEL, i have had it since march and about 12K miles.
-Chris
Old Sep 21, 2004 | 11:10 AM
MaxSpeedSE's Avatar
Yeah too bad your dont have that stock car, cuz id take that test pipe off your hands
Old Sep 21, 2004 | 12:27 PM
liqidvenom's Avatar
brotherhood of tq
u could get an o2 simulator and u wont have a cel
Old Sep 21, 2004 | 02:23 PM
Chickan's Avatar
just take the rear o2 sensor of the exhaust, zip-tie it to the bottom of hte car, and plug the hole it left (or find a shady exhaust shop that will weld it shut is even better). This will get rid of the CEL. I've had my "cat" on for the past 7K miles or so, and I have only gotten two CEL's, which after I reset it, it goes away for quite some time. If you are running forced induction, you might gain up to 20hp from removing the cat, but make sure you don't have to do emissions testing.
Old Sep 21, 2004 | 05:34 PM
Broaner's Avatar
2060lbs and falling...
Don't listen to Chickan. If you completely remove the o2 sensor from the system you will run very rich all the time and be down nearly 15HP. Check this thread in which I clearly explain why this is true.
BkGreen97
Apr 2, 2016 05:47 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
