99 se front end noise
Old Apr 10, 2001 | 05:00 PM
russ29's Avatar
I have a 99 SE auto limited. It has 30k miles and has just developed a high pitched noise in the front on the driver side. It is not the brakes. It does not change when I stop. It changes pitch as I go faster. I think it may be a bearing or axel.
Any ides???
Old Apr 10, 2001 | 05:18 PM
AndyXXL's Avatar
Any ides???
Hmm...weird, I got the same noise on the same side, but it goes away when I stop. Honestly, I have no idea what it might be. Looking for answers myself.
Old Apr 10, 2001 | 08:02 PM
Daniel B. Martin's Avatar
Ideas...
1) Verify that all wheel lug nuts are tight.
2) Raise the car. If you have a floor jack you can raise the entire front end at once, and test both front wheel bearings. No need for jackstands, as you will not get under the car.
3) Grab the top of the tire (12 o'clock) and push away from yourself and pull toward yourself. Yank it to and fro in this fashion several times. If there is noticeable free play or an audible "clunking" sound, the wheel bearing is probably damaged.
4) Attempt to spin the wheel. If it spins freely but makes ugly sounds the bearing may be damaged. If it won't spin at all the brake may be dragging. This could indicate a sticking caliper.
5) Remove the wheel. Make a careful visual inspection of the brake and surrounding parts. See if...
- the stamped sheet metal baffle plate has been bent and is touching the rotor
- a pebble or other foreign body has become trapped and is rubbing against the rotor
boomerbrian
Nov 8, 2015 05:10 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Justin Kroll
Sep 2, 2015 11:06 AM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
