O/D is acting crzy
Old Oct 2, 2004 | 04:12 PM
tedo007's Avatar
faster than you think
O/D is acting crzy
eversince i got the CEL for EGR malfunction my o/d is acting up crzy... like im driving on 85mph and i press the o/d off and floor and press the o/d again my rpm jumps about 300 to 400 rpm more. like 4800RPM with o/d off and after i press it... it goes to5200rpm fast thats kinda strange.
Old Oct 2, 2004 | 06:11 PM
njmaxseltd's Avatar
Once your floored or downshifted out of 4th gear, pressing the o/d buttom has no effect on your engine or transmission shifting.
Keeping o/d off will stop the car from shifting up into 4th gear and the torque converter from locking up.
Old Oct 3, 2004 | 06:18 AM
Kevlo911's Avatar
Kevlo for President
He does not explain it right. I know what he is talking about, I have been in his car. We are doing 90, turn OD off. Lets say RPMs are at 5000. Go WOT, and it goes 5100-5200 and then it stops, it will stay at that RPM and will not move foward. Still at WOT and turn OD on, still in 3rd, right when you push the button, the RPMs jump 300-400 and continue to move foward until 6000 where it shifts into 4th.
My car did this once too when I had the EGR code. Mine does not do it anymore. On his car, he has about 75000+ miles and I don't think the EGR is clogged but something else is wrong with it.
Old Oct 3, 2004 | 09:48 AM
BlueC's Avatar
wat
I have the same problem. Wonder what it is...
Old Oct 3, 2004 | 10:08 AM
Kevlo911's Avatar
Kevlo for President
It has to do with the EGR system. When I reset my ECU it stops doing that and acts normal. Also, when you manually shift, does it shift different then it does at D? Mine doens't feel as smooth manually shifting as it does when its in D(all WOT).
Old Oct 3, 2004 | 10:25 AM
BlueC's Avatar
wat
So, do I need to clean out my EGR system? or what? Thats what im confused about.
Old Oct 3, 2004 | 02:16 PM
Kevlo911's Avatar
Kevlo for President
I would guess so. I am gonna clean mine out within a month when I install the 00VI. Hope the probs will go away.
bryants95max
Oct 2, 2015 12:52 PM
The Wizard
24
Oct 1, 2015 08:47 PM
zmcneely13
Sep 26, 2015 02:26 PM
yamehoo
Sep 24, 2015 10:21 AM
dcardello
Sep 3, 2015 11:44 PM
