RPM meter won't go beyond 25000?
Old Oct 5, 2004 | 06:36 AM
maxlauj95's Avatar
RPM meter won't go beyond 2200?
RPM won't go beyond 2200
95 Max Automatic Tran, When I drive the RPM won't go beyond 25000 and have delay shift. Any comment what's wrong?
Old Oct 5, 2004 | 06:40 AM
NmexMAX's Avatar
dot dot dot ...
Mass Air Flow sensor. Check your codes....READ the STICKIES.
Old Oct 5, 2004 | 06:57 AM
Stephen Max's Avatar
25,000? Dang!!! Mine won't go past 7200, and that's with the rev limit extended.
Old Oct 5, 2004 | 07:00 AM
sunysb83's Avatar
haha, 25000, i was about to say the same thing
Old Oct 5, 2004 | 07:07 AM
MaxedOutOfCash's Avatar
Pizda Boy
you mean 2500 right?
did you beat the heck out of the tranny in the past 15 minutes?
if not then just read the stickies... if you did then turn the car off and wait about 15 minutes...
Old Oct 5, 2004 | 07:08 AM
Longboarderphil
if u just put an intake on ur car did you remeber to plug the MAFS plug back in...if not it will do that. i did that the first time and scared the crap out of myself. if thats not the problem its most likely a MAFS
Old Oct 5, 2004 | 07:12 AM
wariow's Avatar
you need to replace your headlight fluid?
I usually go past 50,000 RPM in 7th gear.
Old Oct 5, 2004 | 07:14 AM
Longboarderphil
Old Oct 5, 2004 | 07:57 AM
maxlauj95's Avatar
know where the MAFS located?
Where can i located the MAFS?
Old Oct 5, 2004 | 08:16 AM
SPiG's Avatar
SomePsychoGuy
It is the black pipe thing on your intake with a box on top of it and a connection. If you just put an intake in then it is what you should have kept from the stock one. If you have not then it may have gone bad for some reason. What year is your car? I know some 5th gens have problems with theirs.
Old Oct 5, 2004 | 08:19 AM
SPiG's Avatar
SomePsychoGuy
Oh and by the way MAFS or MAF is known as the Mass Air Flow Sensor.
Old Oct 5, 2004 | 08:36 AM
maxlauj95's Avatar
It is a 95 GXE.
Old Oct 5, 2004 | 08:51 AM
Sprint's Avatar
its the black plastic thing between the yellow pipes
Old Oct 5, 2004 | 09:07 AM
Maximus_95's Avatar
haha. if it doesnt pass 25000 rpm, you dont have to worry about it. no one's in the org does. check maf. like the pic above
Old Oct 5, 2004 | 09:10 AM
deezo's Avatar
Now that was funny.
Old Oct 5, 2004 | 09:11 AM
gtr_rider's Avatar
192.168.1.1
vtec engages at 10k, no need to rev that high.
Old Oct 5, 2004 | 09:28 AM
Sprint's Avatar
did you know your sig changes everytime i refresh?
Old Oct 5, 2004 | 09:46 AM
tedo007's Avatar
faster than you think
word 25000 why you complaining you should be proud lol
Old Oct 5, 2004 | 09:57 AM
maxlauj95's Avatar
make Correction guys.....Its 2200 RPM....its acceleration slow....help???
Old Oct 5, 2004 | 11:39 AM
1MAX2NV's Avatar
Throttle position sensor. Any check engine light?
Old Oct 5, 2004 | 11:54 AM
lilaclucymaxima's Avatar
Team Ramrod
i wish my car revved up to 25000
Old Oct 5, 2004 | 12:18 PM
Sprint's Avatar
did you install an intake recently? or did you check the MAFS?
gtr_rider's Avatar
192.168.1.1
yes'm
Old Oct 5, 2004 | 12:22 PM
VIP Maxima
which ecu promised u such rpm's
Old Oct 5, 2004 | 08:51 PM
mbenc's Avatar
My **** did that too, scared the crap out of me. That happend after i cut holes in the air intake box. But after it sit for like 30 min at a friends house it was fine. I also reved it up in netural a few times, that seemed ot make it rev higher in gear. Not to mention that most driving over 2,500 rpms is a waste of gas that most .org users do... including myself!
Old Oct 6, 2004 | 12:44 AM
ogparjay's Avatar
foreal, if you can hit 25000 then tells us what you did
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
