ATTN: Anyone with Xenon Lights
I'm looking into purchasing a xenon kit from Meccatune. They use Hella ballasts and bulbs. These are the specs on the kit below:
Product Specifications
Ballast
-Genuine Hella Ballast made in Germany with Integrated Igniter
-35W Power Supply
-Input - 13.2V DC Norm, 3.2A Norm. 20A Max; Output - 35W Norm
-Dimensions - 3.3x3x1.25 (LxWxD); Weight - 2.1 lbs each ballast
Bulb
Hella Approved Japanese Made Koba HID Bulbs
My concern is whether or not these will burn out my harness and wiring. Also, since I use 9004 bulbs, will the light be focused or blind oncoming traffic?
Ballast
-35W Power Supply
Bulb
If you understand how they use separate system for HIDs you would know that they get power directly off the battery and only triggered by the factory harness...
9004 pattern will be horrible and blinding to oncoming traffic... unless you aim them really down (which defeats their usefulness and still there is some glare).
I know which kit you're talking about. That kit from meccatune on ebay is crap. There was a thread up about it a while back. Although the ballasts are said to be "hellas", the bulbs are definitely crap.
You should retrofit some projectors in that bish.
But if u just want the plug and play kit, get the Phillips 6000k kit.
These will not burn out your harness. im guessing you used to use those aftermarket bulbs w/high wattage. These only draw a current of 35w.
and as for blinding ppl in our 9004 housings..yes, u will blind everyone and their mothers
fastcarny
10-06-2015 11:42 AM
-ReLLiK-
09-08-2015 01:02 PM
Maxima30
09-07-2015 07:13 PM
