Power Antenna
Old Oct 8, 2004 | 11:43 AM
JP11283's Avatar
Power Antenna
My power antenna has been stuck up since I got the car. The car has a Sony cassette deck in it when I got it. Even though the antenna was stuck up, whenever the radio would be turned on or off I could hear the antenna making noise. I just replaced the cassestte deck with a Sony CD player and now I can't even hear the antenna making noise. Luckily it's stuck in the up position.
Old Oct 8, 2004 | 03:49 PM
BadKarma99-4spd's Avatar
have some one sit in the car and turn the radio on and off while you listen in your trunk by the antanna and also the outside of the car by the antanna. if you dont hear anything my guess would be that your motor is out, if you do hear something running then the antanna has probably become disconnected form the motor, happened on my 90 max.
good luck
Old Oct 8, 2004 | 05:07 PM
SlackR237's Avatar
Rollin' on 'Caps
If you get that noise from the antenna motor again, you just have to replace the antenna mast...
I had to replace the whole antenna motor after I ordered a replacement antenna that I never used, so if you want a brand new Maxima-specific antenna mast w/ installation instructions, I'll let it go for $20 shipped
Send me an e-mail if you want it!
Old Oct 8, 2004 | 05:18 PM
JP11283's Avatar
It stopped making the noise when I switched out radios. That's whats confusing me. I don't know if it is coincedence or not.
Old Oct 8, 2004 | 05:23 PM
mansurxk's Avatar
did you connect the wire for the power to the antenna? i needed to insert the remote wire as well as the power antenna wire for the antenna to go up and down inmy new jvc deck. if you hear it going, the mast is probalby damaged, its a nylon threaded wire that is moved by some gears in the motor, check ebay for it
Old Oct 8, 2004 | 05:29 PM
JP11283's Avatar
You had to hook up the amp remote wire as well as the antenna power wire? What did you hook the remote wire to?
Old Oct 8, 2004 | 05:53 PM
mansurxk's Avatar
was different for me i guess, i didnt realize you had a GXE, i have a bose so i went through the PAC unit. but it had a remote wire, its a blue wire, connected both teh remote lead and power antenna wire to the blue wire, i dont know how it is on the gxe, im not familiar with audio equipment, i did mine on the fly wiht the help of studman
chisam14
Nov 6, 2018 08:56 PM
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
