Idler pulley torque (Urgent)
Old Oct 8, 2004 | 12:39 PM
idlingmike's Avatar
Anyone got the torque specs?
Old Oct 8, 2004 | 12:59 PM
Flava_24/7's Avatar
Boosted Panda
Checked with Haynes??
Old Oct 8, 2004 | 01:10 PM
Stephen Max's Avatar
Just get it good and tight without twisting the head off the bolt. The amount of torque isn't that critical in this case.
Old Oct 8, 2004 | 01:20 PM
idlingmike's Avatar
You sir, could not be more wrong.
Old Oct 8, 2004 | 07:09 PM
StrikerHA's Avatar
hi i have the torque specs, they are: (4 - 7 N*M which is 0.4-0.7 KG*m which is 35 - 61 ft*lb) , but a better way to check to to see is by the deflection of the belt, since this amount of torque that is recommended by nissan is rarely enough to keep the belt tight, in my experience anyway
Old Oct 8, 2004 | 07:50 PM
sinewave's Avatar
If you can get a torque wrench on the idler pully center nut, you will certainly impress me.
Old Oct 9, 2004 | 12:54 AM
idlingmike's Avatar
Thank you very, very much!!
Old Oct 9, 2004 | 12:59 AM
idlingmike's Avatar
Uhhh....not the nut that holds the pulley itself on, the nut that adjusts the tension of the accessory belt
and FYI, if I wanted to tighten the nut you were referring to, to a certain spec, I'd put the entire assembly on my vice and do so........impressed yet?
Old Oct 9, 2004 | 09:06 AM
BlackCat's Avatar
RIP '98 Maxima SE
I hope you loosened the idler pulley nut first before you play with the tensioner bolt. That nut acts as a lock so adjusting the tensioner won't loosen or tighten the belt until you do that first.
After loosening the idler pulley nut you can adjust the belt tightness by adjusting the tensioner nut from the top. I use a long extension bar to reach it. Once you have the belt to the right specs you lock down the idler pulley nut by tightening it.
Old Oct 9, 2004 | 10:37 AM
sinewave's Avatar
No, not yet. See BlackCat's response.
Old Oct 11, 2004 | 05:30 AM
Sorry, you didn't say which nut or bolt. I thought you were talking about the nut holding the pulley on. My mistake.
James92SE
142
Jan 2, 2024 09:23 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
