Cefiro headlight W/ Xenons
Old Oct 13, 2004 | 05:19 AM
BaiCheSE's Avatar
has anyone had any experience putting xenon lights (with ballasts) into these headlights? how is the light output?
does it get too hot? i know that xenon draws less power than halogen, so does that mean there is less heat?
someone mentioned that if i put HID in the cefiro headlights, it would crack/melt the housing.....
Old Oct 13, 2004 | 07:44 AM
willis's Avatar
My heroine
I could be wrong, but I think you may be mixing up some things. There was a thread a while back about the corner light housing on a cefiro headlight melting from running a high wattage bulb with a nub cut to make it brighter. However, I hadn't seen any about the regular bulb housing part melting.
Like I said, please correct me if i'm wrong..
Old Oct 13, 2004 | 11:25 AM
juani's Avatar
Rockin' VK56!!
since you're mentioning balasts, i assume you're talking about real HID.
I believe real HIDs make less heat than halogen bulbs.
Old Oct 13, 2004 | 12:04 PM
BaiCheSE's Avatar
so is it the corner bulb thas the problem? i plan on running a regular amber bulb in there..that shouldn't be a problem right?
Old Oct 13, 2004 | 06:26 PM
TJ_Max's Avatar
Paradox Systems Vendor
IT SHOULDN,T AND I HAVE REAL HID IN MY CEFIROS, TEMPORARILY, THEY ARE ACTUALLY 9004 HID....I HAVE TO GET THE H4s, AND NOTHING HAPPENED WIT THE HOUSING ON MINE YET, ITS BEEN 2 WEEKS...
Old Oct 13, 2004 | 06:28 PM
Maxtank's Avatar
You should be fine with the HID. But the corner light would melt if you ran hotter
Old Oct 13, 2004 | 06:32 PM
TJ_Max's Avatar
When I Get The H4's Will The Light Output Be Better? Cuz The 9004's Suck In The Cefiros....cant See Anything In Front Of Me..
Old Oct 13, 2004 | 06:56 PM
Sentinal's Avatar
Yeah it does make your corners melt. I have HID's in the cefiro's (9004), and nothing has happened to that part of the cefiros. On the other hand I was running the corners with 1 nub cut and it melted the driver side reducer off and broke the bulb.
Old Oct 13, 2004 | 07:55 PM
TJ_Max's Avatar
mayb ill just get led bulbs for the corner lamps, and how is ure output with the 9004's it sucks doesnt it? if u get the h4s, regular h4 bulbs, will it be brighter and have a better light output?
Old Oct 13, 2004 | 11:06 PM
Maxima Mike
Hey, how are you running 9004 bulbs in the Cefiro lights?
Old Oct 13, 2004 | 11:19 PM
Zigg's Avatar
Remember. Real HIDs are only running about 13-15 watts of energy. That's 1/4 that of your normal headlights at 52 watts. That is indeed a lot less heat being put out. Most of the temperature is in the inner core of the bulb which can get unbelievably hot, yet the outer portions of the bulb are indeed cooler, therefore being harder to melt your housings than would a normal headlight bulb.
Old Oct 14, 2004 | 09:34 AM
TJ_Max's Avatar
i guess that explains it, as for how i got them there, just put the bulb in and close ure hood
Old Oct 14, 2004 | 09:50 AM
Longboarderphil
I have h4 8000k's in my cefiros...they look great and i can actually see in the rain. cuz we all know with hyper whites you cant see sh*t especially when it rains out
Old Oct 14, 2004 | 10:05 AM
TJ_Max's Avatar
how much did u pay for those? i got quoted $700 for H4 HIDS
Old Oct 14, 2004 | 10:24 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
ebay $285 shipped.
Old Oct 14, 2004 | 11:02 AM
TJ_Max's Avatar
what brand are they and what seller? id like to get some from him...
Old Oct 15, 2004 | 01:26 AM
Thahman's Avatar
Hmm... any recommendations on stock headlight housing HID bulbs? Do they make 9004 hi/low beams? I don't see much info on them...
Old Oct 15, 2004 | 07:32 AM
TJ_Max's Avatar
im about to sell mine.....
Old Oct 15, 2004 | 10:50 AM
Wish-it-was-AWD's Avatar
How much for yours, and details Maximus, if it's not too much trouble. Are you simply selling the stock ones since you have the cefiro's now, and are they a true HID?
Old Oct 15, 2004 | 11:44 AM
TJ_Max's Avatar
i dont know how much to sell em for, and they are real, ballast, ignitor, its a reall deal HID kit, and i bought it wit the car, its beautiful, but just doesnt look right cuz its a 9004 in a cefiro H4 housing...its all wrapped up ill peel off enough to read wut brand it is...
Old Oct 15, 2004 | 11:59 AM
So is it a direct bolt-up, wiring and ballast mount excluded, of course, for a 98 with stock housings, etc.?
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
