Can you clean injectors (off the car)
Old Oct 13, 2004 | 08:37 AM
Maxine's Avatar
I have an extra set of fuel injectors and was wondering if i could soak them in a solution to help clean them a little.
thanks
Old Oct 13, 2004 | 12:19 PM
Maxine's Avatar
Well i figured cleaning coil packs and injectors might be alittle different
Old Oct 13, 2004 | 12:28 PM
ThunderMaxi's Avatar
How often are you supposed to clean/replace those? I can't find where it says what interval that is at.
Old Oct 13, 2004 | 12:34 PM
Maxine's Avatar
Got me.
Old Oct 13, 2004 | 12:48 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
replace them when they go.
Old Oct 13, 2004 | 02:12 PM
jbreit's Avatar
there is a company out there that does this...they cycle the injectors while running a cleaner through them. Not sure how well soaking them would clean the actual pintle/valve portion.
Injectors are not a maintenance item like a brake rotor or clutch. They could easily live forever if your car has had an easy life. I would put them on the same order of life as the timing chain in the max....which is considered to be good for life.
I certainly believe in keeping your fuel filter replacement on schedule and a bottle of injector cleaner once or twice a year.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Balkins
Aug 12, 2015 06:39 AM
