for guys that run slicks
Old Oct 16, 2004 | 06:30 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
im planning on runnig some slicks the smallest rim i can use is a 17. what are your suggestions?
Old Oct 16, 2004 | 07:30 AM
I30tMikeD's Avatar
Don't think you can find slicks for 17's......maybe drag radials
Old Oct 16, 2004 | 07:37 AM
pawnstar12's Avatar
well what rim & slick options do us guys with 13 inch cobra brakes have?
Old Oct 16, 2004 | 07:38 AM
I30tMikeD's Avatar
Removing the cobra brakes.
Old Oct 16, 2004 | 07:40 AM
pawnstar12's Avatar
you gotta be kidding me! drag radials it is
Old Oct 16, 2004 | 08:02 AM
Jime's Avatar
1. If you want to run slicks, you want to drag race.
2. You do not need big brakes to drag race
3. Take off the big brakes and you can run 15" wheels.
Old Oct 16, 2004 | 08:16 AM
pawnstar12's Avatar
yeah your right. so when its track day im gonna have to swap back to stock brakes. im cool with that. so what size slick on the 15 inch rim ??
Old Oct 16, 2004 | 09:00 AM
Jime's Avatar
If you are auto I would use 22x8x15's thats what I use. If manual I would suggest 24's or maybe 26's because 1st gear is pretty low.
I run Mickey Thompson's on a 7" Kosei K1 15" rim but you can run the 23 or 26 M&H's on a 6" so the Millenia rim is the cheapest way to go.
Old Oct 16, 2004 | 09:10 AM
pawnstar12's Avatar
im auto
so it would be 23x6x15 on millenia rims?
Old Oct 16, 2004 | 09:30 AM
Jime's Avatar
im auto
Check here, M&H only make the 2 that will fit on a 6" rim, Mickey Thompson doesn't make any that I know of.
7.5/23-15, MHR-21 $140
6.0/26.0-15 MHR-60 $144
http://www.dragracetires.com/m_h.html
Old Oct 16, 2004 | 09:54 AM
pawnstar12's Avatar
thanks... one more question would road race slicks provide better traction than drag radials?
Old Oct 16, 2004 | 10:32 AM
Jime's Avatar
Not sure on that one.
But drag radials are almost next to useless in comparison to slicks. Don't waste your money like I did trying them out.
If you are planning on running N/A in the 14 second area then traction is not that much of a problem, so DR's may work for you, however if you plan on going quicker than that slicks are a big plus. Mine live in the trunk and it only takes 10 mins to change.
Old Oct 16, 2004 | 10:39 AM
Nealoc187's Avatar
SLOW
Pawnstar is turbo. Pawn, go with real slicks don't F around with DRs or R compounds if you want to put down some real numbers.
Old Oct 16, 2004 | 11:11 AM
pawnstar12's Avatar
its just a pain to swap my brakes every time i wanna put my slicks on. thats why i was looking at the pirelli circuit slicks and the hoosier drag radials.
Old Oct 16, 2004 | 11:23 AM
Aaron92SE's Avatar
NWP Engineering.com
Definitely slicks with your kind of power. Drag radials are very close to just good street tires. Well, that's what they are, just good street tires that can also handle well. If you go with DRs, you will be very dissappointed that you can only get a 2.1 60' or worse. But with slicks, Jime has proven with nitrous helping, 1.7s are very possible.
I assume you haven't run your car at the track yet? I am really curious what kind of times and traps you are capable of with slicks. Please keep us updated. Thanks.
Old Oct 16, 2004 | 12:38 PM
BEJAY1's Avatar
Conecarver
Phoenix also makes a 6.0/26-15 PH366. Available through many of the performance catalogs.
http://www.phoenixtire.com/TSpecs.htm
Old Oct 17, 2004 | 08:07 AM
pawnstar12's Avatar
i bring my car to the 1/8 every once in a while. my 60 times are 2.2+ ....yeah they suck! et's are a steady 8.9 - 9.0 ish with around 87mph traps. i get a lot of weight transfer at my launch because i never adjusted my suspension from my street settings.
Old Oct 17, 2004 | 10:29 AM
Dave B's Avatar
Not DAVEB the parts guy
The problem with DRs is no one has figured out to launch with them because so few of us run them. Slicks are a no brainer when it comes to launching, but DRs take quiet a bit of experimenting. DRs can provide plenty of traction especially the new BFG DRs. I've watched a nitrous Viper pull consistent 1.6s on the stock rims and BFG DRs. The problem we have is we're FWD and have very little torque. It takes a lot of torque to motivate a car into the 1.7 and lower 60 foots. Look at Jime and how much nitrous he uses off the line. 1.9x should be within the realm of BFG DRs. I've pulled 2.10 with no burnout on them. I think getting 2.0 should be pretty easy. Slicks will always out perform the DRs, but saying DRs can't get sub 2.0s is crazy. They can do it because there are plenty of other FWD NA 4-banger imports pulling 1.9s on BFG DRs and only about 130fwtq.
Old Oct 17, 2004 | 11:54 AM
pawnstar12's Avatar
i have enough tourqe, 322ft pounds worth
LilVito
Oct 25, 2019 08:12 AM
vybz05
Dec 10, 2015 07:38 PM
max1029
Aug 26, 2015 09:51 AM
maxipower
Aug 21, 2015 11:10 AM
Xi MaX SC
1/4 and 1/8 Mile Racing
Aug 7, 2015 08:47 AM
