Need help from the Gurus
Old Oct 18, 2004 | 09:59 AM
95BLKMAX's Avatar
Hey, I'm going to change my clutch/flywheel HOPEFULLY soon. Anyways, I see alot of peeps complaining about bad tranny bearings. I was wondering how can I tell if I have any bad bearings in my tranny? I figured if I'm gonna have the tranny out, i might as well change them if they happen to be bad. What are the symptoms of bad tranny bearings?
BWT I have a 5spd 95.
Old Oct 18, 2004 | 10:02 AM
amulla01's Avatar
read this whole article...
http://www.motorvate.ca/mvp.php/804
you would get transmission fluid leak with bad bearings...
Old Oct 18, 2004 | 10:03 AM
mzmtg's Avatar
Minister of Silly Walks
I'm not sure how you reached that conclusion.
You would get a leak most likely from bad axle seals, which have nothing to do with the bearings.
Old Oct 18, 2004 | 11:17 AM
Tort's Avatar
I had bad bearings and it was causing my transmission fluid to leak as well. As stated on motorvate.ca "They found excessive play in the 'differential carrier bearing', and this extra play was the reason for the leak. (The seal can only control the gear oil with a slight amount of movement.)"
Old Oct 18, 2004 | 02:00 PM
Terran's Avatar
I hate to say this mzmtg, but you are wrong. Bad differential bearings will eat through axle seals causing them to leak. That motorvate article gives a good explanation if I recall.
toyoking
Sep 16, 2015 07:05 AM
carlmax5
Jan 9, 2004 12:17 PM
phenryiv1
Aug 29, 2002 02:25 PM
GimmeTorq
Jul 22, 2002 02:45 PM
