HELP!!! i'm sick of this!!!!!!
Old Oct 18, 2004 | 12:47 PM
PTownMax's Avatar
I still miss the max
Ok the symptoms of my car are;
1. It will idle anywhere between 800-1100rpms
2. Sometimes it will go to 1200rpm and then drop and stall, sometime takes me as long as 5min to get it to start back up
3. Sometimes when i'm driving and foot's on throttle, the car will jerk back and forth and if you let off the gas it will drop and stall
I've already replaced TPS and cleaned throttle body.
Could these problems be b/c my throttle cables have some slack in them?
I'm Really really really sick of this, i'm starting to hate my max cuz of it
Old Oct 18, 2004 | 12:54 PM
maxlauj95's Avatar
Check vaccum loose, spark plugs, and transmission fluid...if you haven't change like 100000 mile already.....My max like that a month a go...but after transmission flush, TB cleanning, ICAI clean, fuel injector cleaning, change spark plugs....its fine now...car run good...
Old Oct 18, 2004 | 12:58 PM
PTownMax's Avatar
isn't there a danger to doing a tranny flush, as fgor the rest i've done all of that in the past month
Old Oct 18, 2004 | 01:19 PM
Pappa Grande's Avatar
coolant temperature sensor maybe.
Old Oct 18, 2004 | 01:33 PM
njmodi's Avatar
Do I get a tax break?
my buddy's max does the same thing... haven't been able to find the problem yet - no codes set in the ECU... we've already done the following - but it still does the same thing.
1. plugs
2. air filter
3. fuel filter
4. pcv valve
5. replaced IACV valve
6. cleaned throttle body
7. run injector cleaner through it (2 bottles of techron)
8. replaced ECTS
The dealer has had it 3-4 times, each time they plug their consult tool to it, make it stall but then give up since the tool doesn't detect any sensor failures - so they don't know... I've checked the vacuum hoses for leaks - haven't actually checked the vacuum - maybe I need to do that....
Old Oct 18, 2004 | 01:36 PM
PTownMax's Avatar
what bout the idle speed solenoid? Does anyone know the symptoms of it? It's something that won't show up on obd
Old Oct 18, 2004 | 01:39 PM
njmodi's Avatar
Thats part of the IACV - we replaced his with a brand new one... no luck.
Old Oct 18, 2004 | 01:53 PM
PTownMax's Avatar
how many miles does he have?
Old Oct 18, 2004 | 01:55 PM
njmodi's Avatar
somewhere around 90k
Old Oct 18, 2004 | 02:45 PM
PTownMax's Avatar
well atleast it's not a problem with wear, i got 168k
What are some symptoms of a coolant temp sensor?
Old Oct 18, 2004 | 04:22 PM
njmodi's Avatar
Originally Posted by dchon1000
ok what is a PCV valve, IACV valve and ECTS.
is the IACV the same thing as the IAC thats on the sticky??
where can i find pics of the parts?
4. pcv valve
8. replaced ECTS
yes IAC = IACV
pcv - positive crankcase ventilation valve
ects - engine coolant temperature sensor
iacv - idle air control valve
get a haynes manual for pics/location of the parts.
Old Oct 18, 2004 | 05:41 PM
achi913's Avatar
i'm no expert..but a havethe same problem, and the guys here told me to check the MAF sensor (Massive Air Flow Sensor). you can pull your self the cel code (read the stickies) or bye a used maf sensor and changed and see if it gonna work your problem. i did that to my car and stalling was gone.
hope this helps
Old Oct 18, 2004 | 05:47 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
ohm out your ignition coils. they cause the hesistation(jerk back and forth)
Old Oct 18, 2004 | 05:49 PM
njmodi's Avatar
But will they cause stalling and hard or no start, e.g. crank-start-die, crank-start-die over and over for 5 minutes?
Old Oct 18, 2004 | 05:58 PM
killcrap's Avatar
dude, just do it see what happens.
Old Oct 18, 2004 | 06:41 PM
Maxtank's Avatar
whats the ohm range for the coil packs?
Old Oct 18, 2004 | 07:01 PM
njmodi's Avatar
I'll do that - I wasn't trying to be a harda**, I just wanted to be sure that the symptoms were known... its my friends car - so I probably won't get to it until this weekend or next week... appreciate the help.
Old Oct 19, 2004 | 01:17 PM
PTownMax's Avatar
yes i appreciate all the help, after class tonight it's get started checking some of that
Also, i need to know where the coils are and what ohm they should be at
thx.
Would this have anything to do with a bad IAT sensor?
Old Oct 19, 2004 | 06:45 PM
PTownMax's Avatar
bump........
Old Oct 20, 2004 | 02:13 PM
PTownMax's Avatar
ok so delt with the electrical problem i was having and so i could finally check my cell... turns out most of you were right...max is having quite a few problems, but no worries, i've almost replaced or cleaned everything now so by tonight she should be running great!
NJMODI- have your friend check his maf and coolant sensor (mine are both bad) i put the maf in, went for a spin, and so far everything seems to feel better!
Old Oct 20, 2004 | 02:15 PM
njmodi's Avatar
I already replaced his ECTS for him... the MAF is next - but first I'm going to check the coil packs.
Old Oct 20, 2004 | 02:18 PM
PTownMax's Avatar
i'd like to know how that turns out just incase those problems are currently dormant
Old Oct 20, 2004 | 02:22 PM
NmexMAX's Avatar
dot dot dot ...
Maf. . .maf . . .maf
Old Oct 20, 2004 | 02:30 PM
njmodi's Avatar
Knowing my luck it will end up being the MAF - after all the sh*t I've already replaced for him - damn no CEL makes the problem less obvious... sometimes it is fine for 3-4 months and then all of a sudden it stalls 5-6 times over a few miles... what what?.. I'll keep you guys posted on the coil checks...
Old Oct 20, 2004 | 04:27 PM
PTownMax's Avatar
ok, the maf didn't fix it, gonna put the coolant sensor in tomorrow(yawn) also i'm gonna check my coils tomorrow, if it my coils someone said to use mitsubishi, where would be the best place to look for these?
Old Oct 20, 2004 | 07:01 PM
BluFlame's Avatar
check your MAF wiring and connector. I'm 90% sure its MAF related.
1)MAF 2)Camshaft sensor 3)Crankshaft sensor.
Considering you have done all regular maintenance.
Old Oct 21, 2004 | 10:32 AM
PTownMax's Avatar
might still be coils, find out after class today
Old Oct 21, 2004 | 10:35 AM
NmexMAX's Avatar
dot dot dot ...
Might be coolant temp sensor
Old Oct 21, 2004 | 10:55 AM
PTownMax's Avatar
ok, so i went and took out my hanes manual and under "95 and later models" it says it's not applicable, so does anyone know what kind of current i should be checking for?
i know i'm suppose to measure in ohms but i don't know how much is suppose to be there. I need this info asap, thx.
Old Oct 21, 2004 | 11:31 AM
Maximus_95's Avatar
geez man, i posted about this like a week ago and only got like 15 replies. my car was doing the same exact thing. i just replaced my hoses and my mid-pipe, and everything is good. well...at least for now.
Old Oct 21, 2004 | 01:29 PM
PTownMax's Avatar
already replaced the hoses, see no point in replacing my midpipe, but seriously, DOES ANYONE KNOW WHAT OHM MY COILS SHOULD BE AT IF THEIR GOOD? I HAVE A VOLTMETER AND I NEED TO KNOW WHAT OHMS MAKE THE COIL GOOD AND WHAT OHMS MAKE THE COIL BAD
any help would be greatly appreciated
Old Oct 21, 2004 | 04:21 PM
killcrap's Avatar
1 is the number you want. my bad ones were giving me odd numbers like 1500, 1655,1322 etc.
Old Oct 21, 2004 | 05:08 PM
amulla01's Avatar
should be around 1 for good and 0 for bad
Old Oct 22, 2004 | 03:39 PM
PTownMax's Avatar
k gonna check it after engine cools (replacing cts as well)
chucky
28
May 4, 2001 06:27 AM
Soon2BMaxed
Apr 22, 2001 09:13 PM
SkyMax
Apr 13, 2001 08:09 PM
Loe max
Apr 12, 2001 11:54 AM
punkdork
Mar 15, 2001 08:48 PM
