thoughts on this idea.........manifold cross thread workaround
Old Oct 18, 2004 | 01:32 PM
infinitiblast's Avatar
Ok so here is the deal, last time I took off my stocker y-pipe on the hardest to get in nut, the one that you have to use a universal on the whole stud came out too well in the process off attempting to put it back is with a universal joint the first maybe 3-4 threads got jacked up..it starts to grab no then breaks loose..the ones above it however look great.
I got quoted like 125.00 to have it re-threaded...which I find to be rediculous...
First Idea- Buy a tap and die set and try to fix those threads on my own.
Second idea..buy a bolt nut a stud, and put the bolt in from the top down..get a bolt thats a little smaller then the threads so it will slide in..then tighten using a nut and lock washer??
Hows that sound?
Old Oct 18, 2004 | 01:37 PM
mexnamax's Avatar
Looks like you have the two best options that I would suggest already named. Good luck
Old Oct 18, 2004 | 02:11 PM
Kevlo911's Avatar
Kevlo for President
Both sound good. Try first one and let us know.
aw11power
Oct 10, 2021 04:57 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
rnb754
Sep 14, 2015 11:39 PM
thenewguyy
Sep 12, 2015 11:12 AM
