Alarm Beep Mod... mod.
Not to crap on anyone's write-up, because after all, I did use it to do the mod on my car and I thank whoever wrote it, it was nicely detailed and easy to follow.
But in looking at the diagram, I noticed that the relay you have to buy is unnecessary. You can connect the buzzer directly to the car's relay. Connect the black wire from the buzzer to the orange wire from the relay and connect the red wire from the buzzer to the green/orange wire from the relay. Basically connect the buzzer where you would have connected the relay and that's it. It'll work as it should and NO, it won't beep when using your turn signals or anything. It'll work just fine.
NO, there is no danger in wiring it this way. If you look at the diagram, the relay you buy, isn't really doing anything. It's not protecting the circuit, it's simply making the circuit power the relay AND the buzzer. And the buzzer is only 5 mA, extremely low amps, the circuit can handle it fine. If it can handle an extra relay AND a buzzer, it can handle the buzzer by itself.
If the intention of the relay was to protect the circuit, there should be a separate power source for the buzzer so that the relay would just be a trigger and the separate power source would power the buzzer. The way it's wired, the buzzer and the relay are both being powered by the car's circuit.
It's not about saving money, honestly, it would just be an extra $4 bucks for the relay. It's just that the extra relay is redundant and adds extra steps to this mod unnecessarily.
Yeah, I've known about this for a while (about not having to use the relay). I've told quite a few people about it on here, and so far so good. It's good that you made a thread about it though...
Oh, and I'm not sure where you positioned the buzzer when you did this mod, but it makes a huge difference if you mount it outside under the rear bumper.
Originally Posted by acj
...Oh, and I'm not sure where you positioned the buzzer when you did this mod, but it makes a huge difference if you mount it outside under the rear bumper.
oh yea.. i didnt use a relay either
Yea, I didnt use a relay worked fine for me i didnt use a buzzered though, i used a 118 decible alarm, I like it better then the buzzered makes 2 loud chirps. Also if anyone woundered its safe to mount it out side there is a lil rubber thing you can pop out where the wires are and it leads to the outside-back of the rear bumper and just ziptie it to something. Iv driven through a flood still works fine for me.
Originally Posted by Igobuk
Hmm, I didn't think it would withstand weather. So you have it mounted outside of the car, no problems ? If that's the case, I may move it, it was a little too quiet, I was thinking of moving it up against one of the tail lights, I didn't think about mounting outside.
It is definitely a huge improvement over having it inside of the trunk…Oh, and like someone posted earlier, there is a rubber grommet in the trunk leading out towards the license plate, I just used that to run my wires…
hey can you use the door beeper instead of buying one i have disconnected my "door beeper" and do you think if i wired it up it would work? could i just wire it to the power source that blinks the lights or do i need to wire it up "correctly"
Originally Posted by ManualMaxima
you could but yuou would not be able to hear it to well. it is real quuiet. The radio shak buzzer is hella loud. also the back up beeper is good to.
scutmud
Aug 16, 2018 10:56 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
bc992164
Aug 26, 2015 12:19 PM
