What Octane Gas Do You Burn ???
its literally only a 2-3 dollar difference, whats the big deal with spending 2 bucks more when your filling your tank up... but on the other hand. i notice no difference when i use 87 or 89 or 91.. i average the same mileage and same performance
Originally Posted by Netzach
98 only
Feel sorry for you guys only being able to use 93
A VQ will run perfectly fine on 87 octane, but once you accelerate into the higher rpms, the lower octane has a lower knock resistance to the VQ's relatively high compression ratio. Octane basically means knock resistance and a resistance to burn. The higher the octane, the more resistant it is. At WOT with 87 octane, you will not being making as much power as you would with 91-92, but you would be hard pressed to "feel" difference. At the track, you would see the truth though. You'd be .1-.3 seconds slower depending on engine temp, ambient temp, and other conditions. The VQ is more than capable of dealing with low octane gas by simply dialing because ignition advance and richening up the fuel mixture. Anything over 92 octane is overkill in these cars unless you've got an aftermarket ECU.
06-06-2017 02:01 PM
