Low-pitched squeeling noise from left drive wheel (MTX)
Old Oct 28, 2004 | 08:20 PM
Thahman's Avatar
I've noticed while driving between 2-15mph, there's a squeeling noise coming from my left drive axle/wheel assembly... I'm wondering if it's simply a bearing or something, or something inside of the transaxle, which scares me. Any ideas, possibilities, or common probs it could be?
Noise Description- it's not loud at all, just like a soft - "squeek squeek squeek" squeek, which speeds up upon acceleration.
Old Oct 28, 2004 | 08:30 PM
Maximasevspec's Avatar
dose it accour while you turn or just on st8 road?
Old Oct 28, 2004 | 08:39 PM
9maxima5's Avatar
I have the same problem i hate that sound. All of my shocks are blown could that be the reason?
Old Oct 28, 2004 | 08:40 PM
amulla01's Avatar
i hear some squeeling noise but its from my strut, probably the bearings on the strut.
i doubt its the transaxle...
Old Oct 28, 2004 | 09:31 PM
Thahman's Avatar
Hmm... it's on straight road - I notice it when I'm driving in parking lots with buildings around that provide an echo effect... and just a real annoying squeeking sound - wish I knew where exactly it came from, just know it's coming from the left drivewheel, somewhere.
Old Oct 28, 2004 | 09:59 PM
amulla01's Avatar
try getting out of your car and bouncing the front struts from each side and listen for any noises, if it makes noise its probably your struts... that's how I know my struts are going bad...
Old Oct 29, 2004 | 05:05 AM
SMX95's Avatar
i have the same problem, i posted about it a while back nobody replied to my thread.. Im glad to see people did with yours.
Old Oct 29, 2004 | 06:39 AM
Julchen's Avatar
I have a similar problem but it isn't a "squeak, squeak, squeak," its a solid pitch squeal that rises and lowers in pitch depending on speed. I only hear it at slow speed like you said. I'm betting its the bearing, but as long as there is no play and it isn't any louder, I'll leave it alone. Anyone else have ideas? Everyone: This definitely has nothing to do with struts, this noise is clearly coming from something rotating in the wheel/hub area. Bouncing the car, turning the wheel, hitting bumps, etc., is irrelevant.
The only other thing I can think of is that the brake pads always slightly drag on the rotor surface, and in these cars this creates a noise or some kind of resonance. Just a theory.
GregS
Old Oct 29, 2004 | 06:55 AM
Julchen's Avatar
I take back my brake theory. If that were true, then the sound would change or go away when the brakes are applied. My sound persists, brakes applied or not.
Old Oct 29, 2004 | 08:15 AM
97maxrob's Avatar
Mine does the something similar, it's been doing it for at least a few months. I haven't tried taking a look at it yet. I only notice it when the windows are down and I'm driving slow, I think there is a little bit of the sound also when going over speedbumps but bouncing the struts doesn't reproduce the sound either though, braking doesn't effect it at all.
Old Oct 29, 2004 | 09:03 AM
Thahman's Avatar
GregS
Yeah it hasn't a thing to do with my struts, because they're fine, and they're pretty new. It's coming from the wheel/hub/axle.. somewhere in that area.
Old Oct 29, 2004 | 10:17 AM
kingrukus's Avatar
no more maxima...
I have that exact problem. I know it is not coming from the struts or brakes. I think I am starting to develop the same noise on the passenger front wheel now as well.
Old Oct 29, 2004 | 10:39 AM
SMX95's Avatar
yeah everyone has it on the passenger side wheel, mine only happens if theres cars parked around me and its night time, if i have my windows rolled down ill hear it once i start going slow or hit my brakes to go slower, At times if i hit my brakes hard enough and start off again the noise goes away. I read something it could be the brake shield behind the rotor it may be bent, but i checked mine out it seems perfect to me. So im confused as hell.
Old Oct 29, 2004 | 10:43 AM
Ladzio's Avatar
Gentlemen, all of you have symptoms of failed wheel bearing. I have just replaced mine. Bearing is around 20-30 bucks and you can take apart your wheel hub and take it to the shop to have it replaced for another 20-30 bucks (it requires press). Or the whole job will cost circa 100 bucks.
Old Oct 29, 2004 | 10:51 AM
SMX95's Avatar
thanks a lot man!, thats another problem Im going to take care of right away. thanks again!
Old Oct 29, 2004 | 05:40 PM
juani's Avatar
Rockin' VK56!!
having same trouble here. but mine occurs even in high speed.
i can also change the pitch of the sound with pushing or releasing gas pedal.
could it be the same problem??
Matt93SE
May 24, 2019 02:58 PM
trasmadean
Feb 1, 2017 08:20 PM
official_style
Aug 29, 2015 10:10 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
