96 motor w/ 98 ecu no cel. Y?
Old Nov 1, 2004 | 07:31 PM
jcy98maxse's Avatar
Turbo is too much fun!
Well I replaced my 98 motor a few motors ago with a 96 lesser miles motor. Its been running smoothly and everything but I noticed that when I put 98 ecu in there is no check engine light but when I run my TS 96 ecu, it trips the CEL, why is that? I pull the code and it said rear o2 and fuel control module... If the 96 didnt have a rear o2 why would the 96 pull an rear o2 code?
Old Nov 1, 2004 | 07:56 PM
eng92's Avatar
Why do you say that a 96 has no rear O2 sensor?
My 96 FSM shows a 3 wire titania type 02 sensor for the rear.
According to the FSM, the fuel pump control module FPCM (code P1220) is for Cali-spec only.
All the sensors in the 96 and 98 are the same with the exception of the type of rear O2 sensor used.
Old Nov 1, 2004 | 07:59 PM
MaximaSE96's Avatar
Maxima Owner
96 has rear O2 its in the cat.....
Old Nov 1, 2004 | 08:07 PM
Tyrexx's Avatar
the motor doesnt make any difference, you still have the same O2 setup.
Old Nov 1, 2004 | 09:01 PM
MDeezy's Avatar
the 02 setup is the same, but are they interpreted the same way by the ecu?
maybe the 95-96 ecu's have a different numerical value than the 97+ which have the other o2 in anothe location.
Old Nov 1, 2004 | 09:09 PM
I30tMikeD's Avatar
The 96 does have a rear o2 sensor that is not the same as your 98, that is why you get the code.
If your confused about why a 96 motor and a 96 ECU are giving you a CEL, remeber that all the wiring and sensors are still 98.
AaronL
Aug 8, 2020 10:31 AM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
