Brake Light in Console is ON
This just happened yesterday while on the interstate. I hit the gas to pass a car and my brake light in the gauge cluster turned on.
I don't think the brake is actually engaging because the brake lights aren't turning on and the car isn't slowing / stopping. I tried using the parking brake at a red light but it didn't work, the light stayed on after I disengaged the brake. After about 10 minutes of normal driving the light magically turned off.
This morning on my way to work the light turned back on. This hasn't happened before. Anyone have any suggestions, ideas?
Originally Posted by Igobuk
My friend has a Mazda that turns on the brake light in the dash when one of the rear brake light bulbs is out. Do our Maxima's do this ?
I checked to make sure the emergency brake was down (at the red light) and all appears normal. I will also check the brake fluid level to be sure.
It is most likely low brake fluid. If indeed the level is low in the reservoir, check your front and rear pads for wear - they might need replacement. (As the pads wear, more fluid is required to push the piston further - thus the level in the reservoir drops).
The brake fluid reservoir is low (about 1/4 inch above the LOW mark), so I'm leaning toward the pads going out as the problem. Will replace ASAP.
Thanks for the help everyone.
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
