Need help ASAP! Problem starting...
Old Nov 3, 2004 | 09:37 AM
Daily Interlude's Avatar
95 Maxima Auto:
Has always had it's problems starting. Now when I turn the key to start it, I get a bunch of clicks. When I leave the ignition on (but not trying to turn it over) I hear a quick but soft ticking around the front side of the tranny. there's something that protrudes from the tranny, roundish, with a "#7" on it. Sounds like it might be coming from there...
Any idea? Maybe starter?
Old Nov 3, 2004 | 01:41 PM
bump to the top
Old Nov 3, 2004 | 02:27 PM
mansurxk's Avatar
sounds like the starter
Old Nov 3, 2004 | 02:31 PM
Dubbya's Avatar
VK56 Inside
I would bet on the starter.....depending on how many times you tried to crank it with a bad starter you will either need to charge the battery or buy a new one.
Dub
Old Nov 3, 2004 | 02:51 PM
Broaner's Avatar
2060lbs and falling...
That thing with the seven is not the starter. Follow the postive line from the battery and you will find a zinc finished cylinder. Thats the starter. The clicking when the car is in the on position is normal. It should go away after a few seconds but should come back when the gas is depressed. Don't worry about those clicks. The clicking that you get while the key is in the start position is the issue. I've never had a bad starter but that sounds like it could be. Check all the connections. I mean all of them. I often unplug a connection while working on something and forgot to plug it back in. The result is often no start. Then take the required steps to check the starter itself.
Old Nov 3, 2004 | 04:31 PM
Dubbya's Avatar
VK56 Inside
A bad starter definately clicks. I have had 2 go on my Max and they just click and click and click and click and..........
Old Nov 3, 2004 | 04:39 PM
mansurxk's Avatar
yeah sounds like the solenoid is fine because it is clicking, but the motor isnt turning, you can take out the starter and check if the grease it all gummy now, regrease and test it by connecting it toh ebattery to see if teh motor spins on the starter.
Old Nov 3, 2004 | 07:46 PM
OK, I had Autozone check the starter and it's engaging fine. I'm bringing another battery with me tomorrow just to verify it's not the battery though I'm pretty positive it's not.
The ticking stays on no matter how long the key is left in the on position. It only goes away when I move the throttle rotor. Is there a fuel pump or something fuel related that could cause this soft ticking?
Old Nov 4, 2004 | 06:55 AM
bump up top
Old Nov 4, 2004 | 01:30 PM
Anyone?....
Old Nov 4, 2004 | 02:09 PM
PTownMax's Avatar
I still miss the max
whenever i forget to turn my lights off and my battery dies, if it's got a little juice but not enough to crank then it makes a clicking noise, have you tried a jump start or charging the battery? also the ticking your describing could be coming from an idle controller, and a mech. with 30+ years under his belt told me it was pretty normal to get the clicking while in acc
hope this helps
Old Nov 5, 2004 | 08:58 PM
Well, it winded up being the battery. i was able to jump it off and I let it run for 15 minutes at idle. Cut it off and then tried to immediately start it and more clicking. One battery later and it's like it was before (hard start but turns over every time). Next job is to check the crank position sensor...
NewMax03
Oct 29, 2015 07:44 PM
homewrecker
Sep 24, 2015 07:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ajahearn
Sep 19, 2015 03:03 PM
chernandez1278
Sep 16, 2015 01:18 PM
