TechnoSquare 95/96 ECU UPDATE! Rev Limiter Found.
Old Nov 12, 2004 | 10:21 AM
  #81
TJ_Max's Avatar
Paradox Systems Vendor
Originally Posted by michaelnyden
of course you wouldn't have to send it back in, what this thread is about is that for the longest time the TS ecu didn't raise the rev limiter...the new program is the same as the old on, only with a higher rev limiter....so just get the ecu now and you will get the new program with the raised rev limiter and be done with it so when you get your mevi, you'll be good...
GREEEEEEEEAAATTTTTTT!!!!!
good info, im doing this real soon....we have until december 15th though
Old Nov 17, 2004 | 03:04 PM
  #82
Chebosto's Avatar
RIceD OuT moDErAtor
bump bump..
still available.... quick! before the time runs out-
if you have MEVI, you MUST notify them so they can change the A/F accordingly..
Old Nov 17, 2004 | 03:31 PM
  #83
michaelnyden's Avatar
how will they know what to put the a/f as if you have the mevi? have they dynoed max's with mevi's and know what a/f they require up top?
Old Nov 17, 2004 | 04:08 PM
  #84
Flava_24/7's Avatar
Boosted Panda
Originally Posted by Chebosto
bump bump..
So can I send my G force ECU in and have its REV limiter raised for the 50$ charge???
Old Nov 18, 2004 | 09:30 AM
  #85
TJ_Max's Avatar
we have almost a whole month.....and i thought u can get a mevi later and it ADJUSTS to it, now whats the story with it??
Old Nov 18, 2004 | 09:31 AM
  #86
TJ_Max's Avatar
how much if u buy an ecu from them?
Old Nov 18, 2004 | 09:38 AM
  #87
abci30's Avatar
oh noes!!!!1111
Subject: Re: maxima ecu upgrade
Have you ever dyno'ed your car with the new variable intake? If so, could you send it over with the A/F chart? As far as A/F, it shouldn't matter too much. But we'd like to see everyone's individual A/F chart anyway.
Old Nov 18, 2004 | 09:40 AM
  #88
eng92's Avatar
YOu should be able to pick up an ecu out of a local wrecking yard or on car-part.com for < $100.
Old Nov 23, 2004 | 10:52 AM
  #89
eng92's Avatar
TWO THUMBS UP FOR TECHNOSQUARE CUSTOMER SERVICE (with a little help from FED-EX)
My ECU landed at their shop yesterday at 11:30 PST. It is back sitting on my desk today at 13:00 EST.
Old Nov 23, 2004 | 12:46 PM
  #90
Rowan's Avatar
wow, hadn't checked back in awhile!
great work TS, and thanks Chebosto and Deezo.
No if I can only come up with the 400 bucks. Argh, I was going to put it into projectors or leather. Darn it. Decisions, decisions.
Old Apr 17, 2005 | 09:24 AM
  #91
aznsap's Avatar
any chance a deal on the TS ECU will be revived?
also just outta curiousity, how does the TS ECU affect gas mileage for NA applications?
Old Apr 17, 2005 | 12:08 PM
  #92
maximazation's Avatar
gas mileage stays pretty much the same, until you get on it
Old Apr 18, 2005 | 05:25 AM
  #93
nismology's Avatar
Gas mileage will be the same if not better than stock overall (if you maintain the same driving habits). During closed-loop operation O2 sensor feed-back is still used to keep the A/F ratio close to 14.7:1 so gas mileage will be identical in this case. During open-loop operation the gas mileage will improve over stock since the ECU is tuned to run leaner in this condition.
Old Apr 18, 2005 | 09:22 AM
  #94
aznsap's Avatar
thanks. when does the ecu operate closed-loop and when does it operate open-loop?
Old Apr 18, 2005 | 09:57 AM
  #95
Broaner's Avatar
2060lbs and falling...
Closed loop is part throttle and IIRC warm idle. Open loop is cold start idle and WOT.
Old Jul 28, 2005 | 03:20 PM
  #96
sean05's Avatar
any chance of another deal?
Old Jul 28, 2005 | 04:22 PM
  #97
konak85's Avatar
ye same quest.
Old Jul 28, 2005 | 06:38 PM
  #98
sean05's Avatar
Originally Posted by konak85
ye same quest.
i doubt it will happen
Old Jul 28, 2005 | 06:52 PM
  #99
chillin014's Avatar
where can i read about all of this. I dont really know waht an ecu is, or anything about these ratio's and timings. But i am interested in the upgrade and i dont want to get flamed for asking a bunch of questions.
thanks
Old Jul 28, 2005 | 08:16 PM
  #100
ewuzh's Avatar
donate 20 and search?
In short, the ECU is a car's computer. The stock fuel and ignition mappings are not the best so a technosquare or jwt ECU upgrade reprograms the ECU with an optimized version of these mappings/timings. You can also raise your rev limiter and/or get JWT/TS to fine tune your ECU if you have a turbo or supercharger for even better performance.
With an upgraded ECU, you're lookin at broader torque curve and higher peak hp figures (15hp+).
Old Jul 28, 2005 | 08:39 PM
  #101
Flava_24/7's Avatar
Boosted Panda
Kinda true.
With the Technosquare ecu you get the adjusted AFR and advanced timing.
With a couple of autos they were able to raise the rev limiter.
The JWT offers the same, but also raises the rev limiter. JWT also has programs for Forced induction and NO2 setups.
Modded ECU's give you much better low end and increased throttle response.
Old Jul 29, 2005 | 04:59 AM
  #102
deezo's Avatar
...and this thread is done.
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
