Cost to fix Right outer axle
Hi
I have a 1995 nissan maxima. 84K miles.
I took it to walmart for oil change and they did not do it and told me that there was oil plug gasket and pan was damaged.
My mechanic saw the car and found
1)right outer axle leaking some fluid and told me to get it fixed . cost is 135$.
2)and the oil pan will cost 60$ to fix it or 175$ for new one.
are these prices ok
are these prices ok
More information needed
Originally posted by adibmotiwala
Hi
are these prices ok
Hi
are these prices ok
What will you get for $135? A replacement CV joint boot? A replacement CV joint? A replacement axle shaft?
What will you get for $60? A repair done by welding? A repair done by epoxy cement? A one-size-fits-all rubber drain plug?
Are these prices in US$ or Cdn$? It makes a difference!
I suggest you get a second opinion from a different repair shop... and be sure you come away with more specifics about the damage your car has and the proposed method of repair. Don't be ashamed to stand there, asking questions and taking notes. If the technician isn't able to communicate his ideas in simple terms maybe he isn't able to repair your car properly.
Re: More information needed
the mechanic/body shop quoted 135$ to remove the CV boot,
fix the rubber part and grease it and fix it back.
can u tell me the difference between Cv joint boot and just
Cv joint and is there something like CV boot.
all prices are US dollars
basically the oil pan has a dent. and the screw looks like it has jumped a thread and maybe damaged.
so the mechanic said he will try to fix the pan if he can open the screw and replace the gasket.
Hi
are these prices ok
Hi
are these prices ok
Joints and boots
... can u tell me the difference between Cv joint boot and just Cv joint and is there something like CV boot. ...
Re: Re: Joints and boots
So is 135$ US good enough to repair the CV right outer boot. that includes whatever is needed to repair it , grease it and labor.
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
Sep 5, 2015 10:10 PM
