Oil pan leak after synthetic use
Old Nov 9, 2004 | 10:44 AM
THT's Avatar
THT
Throbbing member
I was replacing my DCCC with my stock orange lights today when I noticed a very small, fresh oil stain in my parking spot. I got under the car and saw that the bolt keeping the oil in the pan was leaking oil at a very very slow rate. Now, this has never happened before but the last time I changed the oil (100 miles ago) I switched to Mobil 1 10W-30; until now, my car has only seen regular oil. I have about 73,400 miles on the engine so I didn't think switching would cause any problems. Anyone have any input or suggestions? Am I worrying about something normal?
~THT
Old Nov 9, 2004 | 10:45 AM
Jeff92se's Avatar
I'm needing a caw
Retorque the oil pan bolts?
Old Nov 9, 2004 | 10:47 AM
THT's Avatar
THT
Throbbing member
Yep, did that. The bolt was tight but I loosened it and tightened it again. To be safe, I added about a quarter quart of oil too.
~THT
Old Nov 9, 2004 | 11:05 AM
SkoorbMax's Avatar
Are you sure the oil wasn't leaking from above the bolt - maybe the oil pressure sensor? If not, and it was only the bolt, grab a new one of those squishy nuts (you know, what fits between the bolt and the pan), and put it in there.
I can't think of a better term than squishy nut, since that's what it is - a nut made of pliable metal.
Old Nov 9, 2004 | 11:07 AM
mzmtg's Avatar
Minister of Silly Walks
Did you replace the copper gasket on the bolt like you are supposed to?
Old Nov 9, 2004 | 11:08 AM
njmodi's Avatar
Do I get a tax break?
^^^^^ he said it... as long as you mean that oil was leaking from the oil pan drain bolt (not the oil pan itself) - just replace the copper washer.
Old Nov 9, 2004 | 11:46 AM
THT's Avatar
THT
Throbbing member
Copper washer? No copper washer there to begin with. Then again, I am the third owner of this car (Grandfather and father owned it before me) and they tended to do half-*** DIY jobs. Looks like I need to get a copper washer. And yes, it's the drain bolt that's leaking for sure. Thanks for the responses.
~THT
Old Nov 9, 2004 | 03:30 PM
Dubbya's Avatar
VK56 Inside
Step 1.
Remove all synthetic oil.
Step 2.
Use conventional oil
Unless you start out with synthetic dont use the stuff. It is bad to switch over. I had a very similar problem. I told my mechanic (builds race cars), and he was like "Hmmm, all you did was change your oil and you got a leak? That doesnt sound right." Then I told him that I used Mobil One. "Go drain your oil and replace with regular oil and your leak will go away." I replaced it and VOILA, no more leak.
Old Nov 9, 2004 | 03:32 PM
Jeff92se's Avatar
I'm needing a caw
Step. .1 Buy a $0.0003 copper drain washer and install it on the drain plug.
YOu really have no idea what you are talking about.
Originally Posted by Dubbya
Step 1.
Step 2.
Ant96GLE's Avatar
Your totally lost... the only reason why synthetic caused the leak is because synthetic has stronger detergents which have the ability to get through seeps easier. If you have a leak, dont just change back to conventional oil.. fix it.
Old Nov 9, 2004 | 03:36 PM
Dubbya's Avatar
VK56 Inside
Ok, not to get into a pissing match, but my mechanic knows what he is talking about. Im really just saying there is no reason to go to synthetic in the 1st place. If you have been running conventional the keep doing it. I have 189,000 miles on my car all with conventional oil. Is synthetic gonna buy me anything that the conventional didnt do in the last 189,000 miles? NO. In my case its not so easy as to replace a washer (front main seal) so switching back to conventional IS way more cost effective.
Old Nov 9, 2004 | 03:40 PM
Ant96GLE's Avatar
Synthetic is a superior oil, not only will it withstand heat for much longer than conventional it protects the engine alot better too.
You dont have to have a race car to see its benefits.
And who said anything about the front main seal? They're talking about the copper gaskets on the oil pan... which are as each to change as your oil.
Old Nov 9, 2004 | 03:42 PM
Jeff92se's Avatar
I'm needing a caw
I doubt that
How do you know? Maybe your engine is all sludged up with crap and just so happens to still be running? If you ran synthetic all this time, it would be much cleaner. Neither you or your mechanic could really comment on this accurately. No one could.
Um don't know about the VQs but I can do a front seal in about 1 hour.
Old Nov 9, 2004 | 03:44 PM
Dubbya's Avatar
VK56 Inside
Oh, scuse me for stepping into your thread. I was just posting my opinion of synthetic oil. I will go find a public forum to do so.
Old Nov 9, 2004 | 03:46 PM
Jeff92se's Avatar
I'm needing a caw
You want to post inaccurate facts about synthetics, you will be corrected. Sorry if that flies in the face of what you mechanic tells you. But now you know better and can lead a happy life.
Lonely Driver's Avatar
Vqs can be done in 30 min.
Originally Posted by Jeff92se
I doubt that
Old Nov 9, 2004 | 03:49 PM
Jeff92se's Avatar
I'm needing a caw
Well if I really went to town, I could probably do it in 20 min. If it's just the seal itself, that only takes me 2 min
Old Nov 9, 2004 | 06:48 PM
98MAX4ME's Avatar
Hey all,
This is a great site, I regret not finding this site earlier. I've owned my maxima 98 GXE since new.
I've thought about going with Mobile 1 for both my vehicles, but have refrained from doing so by all this leak talk. Both cars have always had regular oils used. Do you guys think it's a good idea for high milage vehicles to start using full syn oils? Any experiences/success/failure stories? Thanks in advance for your input.
Keep up the good work. I thought the lexus owner's forum was good, you guys are just as good if not better.
Cheers
Jay
Old Nov 9, 2004 | 07:09 PM
MDeezy's Avatar
I agree that if you have a leak switching back to the non sythetic oil isnt the solution, good thing the sythetic found the leak before it could turn into something big down the line but your regular oil wouldnt leak it so you didnt know until something bad happend.
I'm going to be switching to sythetic soon, and have done research and know how much better for the engine it is than regular oil. I'll post my results.
Old Nov 9, 2004 | 07:43 PM
NismoTunin's Avatar
u can use me as an example 236K MAX... I use Mobile 1 fully synth. since 50K on it or so never head a leak till 200K when my oil sensor started to leak through the wire holes.... and my car runs great no blue smoke no leaks.... i dont know wtf are these idiots talking about here that synthetic brakes ur engine.... in my case it made my car last longer with no engine problems.... and very smooth operation too...
btw we are gettin off topic here.... i know my words dont count here since i joined not too long ago... but wats with all the BS going around lately here....
just my 2 cents....
Old Nov 10, 2004 | 10:22 PM
GKET36's Avatar
mobil 1..... 420,000 extremely hard miles and still runs like a charm. My 1982 max also mobil 1 had 410,000 before being wrecked so dubbya I wouldn't put a lot of value into what your mechanic says.
Old Nov 10, 2004 | 10:26 PM
Ant96GLE's Avatar
Your current Maxima has 420,000 mile? Holy bajesus, take a pic of your odometer, I would love to see that!
Old Nov 10, 2004 | 10:29 PM
GKET36's Avatar
i don't have a digital camera yet(spending all my money on mobil 1 every 4-5 weeks).
Old Nov 10, 2004 | 10:33 PM
Ant96GLE's Avatar
Damn how many miles do you put on your car a week? I thought I was bad, I put 53,000 miles on my car in the past 2 years.
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
