Resetting the ECU
This link works just in case you want to reset the ECU anyway or if you want to pull codes from the car if any.
http://vbxmaxima.8m.com/ecu.html
Resetting the ECU only clears stored error codes, it does not in any way change or erase stored operating parameters.
In fact, the Haynes shop manual doesn't recommend disconnecting the battery for long periods of time because the ECU can lose that information over time. It goes further to say that if that happens your car may run rough until the ECU relearns the cars correct operating parameters.
if you must... disconnect the battery, hit the brakes a couple of times and that will clear and "residue" energy that is left in the car.
You really don't need to reset the battery to do the intake.
take care and good luck
Omar Abdurrahman Siddiqi
08-26-2016 05:18 PM
220k+ A32
09-22-2015 03:08 PM
