Axle Installation Q's
Old Nov 10, 2004 | 01:52 PM
Frank_Askew's Avatar
I am about to put in new axles and belts (non abs and non lsd) in my 95 SE and I was wondering if there was anything that I needed to know before I started to watch out for? What else should I do while I have the wheels and all the other parts off the car? I am currently at 150K.
Thanks!
Frank
Old Nov 10, 2004 | 02:38 PM
njmaxseltd's Avatar
The castle nut that holds the axle onto the hub is very tight, you'll need an impact gun to get it off. Disconnect the lower strut mount so the hub and rotor can swing out to give you room to get the axle out. The driver side usually comes out with just a pry at the transmission. The passenger side needs to be pryed at the jurnal bearing after you loosen the 3 bolts in the middle of the shaft. It's a PITA take your time.
Old Nov 10, 2004 | 02:40 PM
SkinnyMax's Avatar
maxima no more
only thing that you really need is the 36mm socket for the axle nuts and some serious leverage to get them off. you should change the tranny oil since half of it will come out when you pull the axle anyway. and remember that you should get an alignment done after the new axles are in.
Old Nov 10, 2004 | 02:43 PM
Jeff92se's Avatar
I'm needing a caw
Review this article and bookmark that site. http://www.motorvate.ca/mvp.php/401
Probably one of THE best diy sites I've seen.
matts95max
Apr 23, 2025 10:44 AM
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
boomerbrian
Sep 4, 2015 08:25 AM
