cv joints replacement
Old Nov 13, 2004 | 04:18 PM
SHADETREE95's Avatar
anybody know if you have to pull the passenger cv joint first or can you pry the driver side without removing other side chiltons says you gotta pull the passenger side first and pop it out through the other side.
Old Nov 13, 2004 | 05:25 PM
z32drifter's Avatar
When I replaced mine ... I just used my large pry bar between the joint and the trans case.... it came out fine.. didn't even take much pressure
Old Nov 13, 2004 | 05:59 PM
amulla01's Avatar
mine didnt pry out... dont take out the other side's axle, it would be stupid... just grab the drivers side axle and pull it out as hard as you can and you will see it is quicker and less annoying than lying underneath the car and trying to pry the thing out...
Old Nov 13, 2004 | 09:56 PM
izzydig's Avatar
I used an explosive/snapping action. I'm sure it would be better if you pulled...really hard.
I just yanked the bisch out (had to leave on a 2K trip 1 hour later).
We'll see if my tranny's bearings fuxor up over time.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
