Did I buy wrong year......?
Old Nov 14, 2004 | 07:51 AM
bhaske1's Avatar
Hi,
I "had" and sold a 98 Maxima, never one problem. Thinking all 4th Generation Max's are the same and it was time for another sedan, I bought a '96.
Curious why the taillight mods start for '97 cars.
Wondering if there are any other concerns, mods just for pre-'97 cars.....
THANKS!!!!!!
Old Nov 14, 2004 | 07:58 AM
tavarish's Avatar
fwd gone rwd cr00
yes, you definitely bought the wrong year, the 96 is known to explode after a cenrtain mileage.
watch your a$$
Old Nov 14, 2004 | 08:13 AM
BigLou93SE's Avatar
watch your a$$
is this a joke???
bhaske1 -- If you have a 5 spd., you may be screwed, but other than that, my car turned 134k miles the other day, and I'm only throwing the knock sensor code (which is normal for all years). Run the ecu diagnostic test for piece of mind, and perform some general maintenance.
If you don't like the stock taillights (I do, actually) then you're S.O.L. as far as replacements except for altezzas , but you can tint them/red them out.
Old Nov 14, 2004 | 08:16 AM
JClaw's Avatar
What the hell is wrong with 95-96 5-speeds?
Old Nov 14, 2004 | 08:28 AM
bhaske1's Avatar
It is a 5 speed. I just ordered a short shift kit from:
http://www.customenterprise.com/view.../vts/design004
The transmission feels very good, no clutch slip.... yet hehehe
I'm just having weird things happen. The sunroof is now stuck open/tilt. The BOSE radio backlighting is out. There is some loud screeching noise from the timing chain cover. Although I bought it last week and have not had the chance to check it all out yet.
I decided to eventually tint my rear lamps and I ordered the clear front turn signals.
Looking for stock 98 SE 5 spoke 16in wheels. Plan to buy a suspension VERY soon. Maybe someone has a good headunit to donate ;-)
Old Nov 14, 2004 | 09:08 AM
PTownMax's Avatar
I still miss the max
all of you can go to hell, IMO, the 95-96 are the BEST year model, due to less emissions restriction and less curb weight (+ the better looks) the 95-96 can actually be faster stock vs stock
Thank you very much
Old Nov 14, 2004 | 09:15 AM
Half_Lunatic's Avatar
Thank you very much
Represent!
Old Nov 14, 2004 | 09:16 AM
Icudie's Avatar
Yes please ol' wise ones fill us in on why a 5speed 95-96 is trash..
Old Nov 14, 2004 | 10:58 AM
*FleXIMA*'s Avatar
<<96 auto 134000 and still goin strong
Old Nov 14, 2004 | 11:02 AM
JClaw's Avatar
Yep, 95-96 are the best bang for the buck, price wise, and arguably the fastest 3.0's.
Old Nov 14, 2004 | 11:13 AM
Fekz's Avatar
I have 96,5xx miles on my 96. It's a 5-speed, tranny is very strong and smooth, not anticipating any problems any time soon. I hear the 98-99 maximas have coil pack/o2 sensor issues, but hey who knows. I believe I made the best decision in purchasing a 96!
Old Nov 14, 2004 | 11:15 AM
mansurxk's Avatar
ole wise one speaks the truth, a good % of them are plagued with a factory defect with the incorrect shim size, this results in early failure of differential bearings. type in differential bearings in search and see what comes up. its pertinent to the 5speeds of 95-97
Old Nov 14, 2004 | 11:16 AM
tavarish's Avatar
fwd gone rwd cr00
obviously your car's not a time bomb, it was a joke.
I think the 95-96 "looks" are dated, 97-99 are much better IMO.
95's can win stock vs. stock, but only marginally, and there would be alot of other variables to throw in, so it's pointless to compare the two, they're the same car essentially. It doesn't put out any more hp, and doesnt weigh alot less, less than 50 lbs difference.
I wonder if there's a 95-96 conversion for a 97-99....kinda pointless, dont you think?
again, its the same car, and its jut my opinion that a 97 will look better than a 95.
Old Nov 14, 2004 | 11:17 AM
mansurxk's Avatar
i think if i were to do it again, id get a 98, i havnet had the differential bearing problem....knock on wood, but bad coil packs are no reason to pass up the 98 or 99, and o2 sensor isseus are on all 4th gen models and it would cost $200 at most to replace all 3 on a fed spec model...
Old Nov 14, 2004 | 11:20 AM
Fekz's Avatar
Yeah, I understand where your coming from, but 5k was all I had to work with. At that range I believe I found the best deal (at least in my area)
Old Nov 14, 2004 | 12:00 PM
PTownMax's Avatar
got 169k on original engine and tranny, besides a few sensors here and there it runs like a beast
Old Nov 14, 2004 | 12:12 PM
mansurxk's Avatar
mines got 130k and still runs well, but the fact is there are still problems with certain trannies in these years.
Old Nov 14, 2004 | 12:44 PM
bhaske1's Avatar
Well I appreciate all the comments, but have to agree and disagree.
My Auto '98 SE was WAY better looking as far as, front end, rear end, BOSE stereo, Climate controls.
But this 96 SE I got is a more fun to drive, due to its 5 speed.
Old Nov 14, 2004 | 02:08 PM
RA030726's Avatar
I'm nutty for Nissans
Sorry CarbonDreams95 and JClaw. the fastest stock 4th gen is a 97.
Old Nov 14, 2004 | 02:19 PM
PTownMax's Avatar
and how did you come to that conclusion?
Old Nov 14, 2004 | 02:33 PM
Vyrus's Avatar
This thread is just turning into a "my car is better than your car" dispute. Rather pointless.
To answer your original questions bhaske1, the problems typical to 95-96 Maximas are transmission bearing failures, knock sensor failures, and occasionally O2 sensor failures.
They make several altezza style tailights for the 95-96 Maxima, if that's your boat, and they used to make red/clears. There are a few different tailights out for the car, just not the red/clears you are thinking of.
-Cyrus
Old Nov 14, 2004 | 02:47 PM
philly96maxima's Avatar
watch your a$$
I have 186k on my 96 no leaks and running strong!!
p.s. PUTZ!
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
