California Spec...Pros/Cons?
Old Nov 14, 2004 | 11:12 AM
Millwoodva's Avatar
'98
5 speed
SE
92,000
Just checked my data tag and found I have A Cali spec. I was surprised that it was cause it was "raised" on the eastcoast...
Per the org.s FAQ's....my 12th charactor is "V". Do they have additional o2 sensors? Maybe the y-pipe I won off ebay yesterday will not fit....
Old Nov 14, 2004 | 11:19 AM
tavarish's Avatar
fwd gone rwd cr00
your car will have the need to surf and go to rock conerts and call everyone else "shoobies"
You might have to get a cali-spec y-pipe....they ask you that when you order from budget...i've heard....
I don't believe there are any more O2 sensors, I just think the exhaust has more restrictions, more precats...
but i could be wrong..
Old Nov 14, 2004 | 11:21 AM
Zack342's Avatar
NO PROs and all cons
Old Nov 14, 2004 | 11:39 AM
Millwoodva's Avatar
ok zack342....and the cons are.....?
Old Nov 14, 2004 | 11:48 AM
Eldinhasamax's Avatar
I just bought a y-pipe and it dosent fit my max i need more 02 hole for it i ask for 4 and the y-pipe on Ebay only has 2 so it wont work it sucks there are more o2 sensors on cali max
Old Nov 14, 2004 | 03:11 PM
chenzarino's Avatar
4 O2 sensors on the cali max, plus the opening from the front side header is HUGE to fit the SECOND precat, a fed spec y-pipe wouldnt fit if you tried. If it's not a cali-spec y-pipe it aint gon fit.
Old Nov 14, 2004 | 06:22 PM
JSMEXUSA
I bought mine in CT and it is Cali specs with 4 sensors instead of 2 from Fed. I was saving up for a Y pipe but it seems like only one precat is removed of instead 2 precats removed for Fed espec; so I think that it means won't get to much hp gainsas the Cali cars get, but not sure, so probably Y pipe will be just another waste of money for me. Can someone post the cons of having Cali specs?
Dasmith
Aug 25, 2015 10:15 PM
laflyer23
Aug 22, 2015 10:04 PM
Maxgig
Aug 18, 2015 09:17 PM
MaxStock
Aug 12, 2015 08:33 AM
RcticMax
31
May 9, 2001 03:16 PM
