Gas Mileage
Gas Mileage
The gas mileage on my 1999 Nissan Maxima GXE has droppped. I used to get about 26 miles to a gallon, but now its dropped to about 21. I changed my fuel filter, cleaned my fuel injectors, but still no improvement. What could cause this drop in gas mileage???
Assuming you have no engine codes, I would also blame winter gas, and the longer warm up time your engine has in colder weather....especially if it sits outside overnight.
Just thinking out loud, there could be some other rare mechanical issues...bad wheel bearing(s), sticking brake caliper, alignment problem. A bad coolant temp sensor would throw a code and have other problems around it, as would an EGR valve. Knock sensor may be on the way out, and that will not throw a code.
I am assuming your other maintenance is up to date....plugs, tranny fluid namely
Those are the only idea's I have....
good luck.
JB
good luck.
JB
check your ecu codes, check tire pressure, bad o2 sensors can cause bad gas mileage. People have said that the knock sensor can cause bad gas mileage, but doesnt trigger the check engine light.
Originally Posted by Broaner
You lowered? Have you bottomed out lately? Get on the ground and check that your rear o2 is intact. That sensor has been the culprit of my bad fuel mileage three times.
I think he meant, "did you drive over a speed bump/curb/object that bumped the under-carriage of your car?" - which could have potentially damaged your O2 sensor... but as I had already stated, the O2 sensor that could potentially damanged by such an event doesn't affect gas mileage (the one downstream from your cat).
06-06-2017 02:01 PM
