Replacing Y Pipe
Old Nov 17, 2004 | 05:26 AM
seemaxgo's Avatar
Replacing Y Pipe
I am thinking of replacing my stock Y pipe. I see that it eliminates some pre-cats used for cold warm up and once warm the sytem works fine. A question I have is does this activate the check engine light all the time when starting?
Old Nov 17, 2004 | 05:33 AM
mzmtg's Avatar
Minister of Silly Walks
No, not at all.
PLUMMAXSE's Avatar
Your check engine light should not come on, unless you screw up installing the y-pipe. The 2 O2 sensors will need to be removed from the old pipe. Also when you tighten the y-pipe to the engine it needs to be torqued to 35-40 ft lbs to keep air from getting into the pipe. Good Luck!!
Old Nov 17, 2004 | 05:35 AM
mzmtg's Avatar
You mean to keep the exhaust from leaking out.
Old Nov 17, 2004 | 05:48 AM
seemaxgo's Avatar
Thanks, appreciate the replies.
Old Nov 17, 2004 | 07:10 AM
PLUMMAXSE's Avatar
Thats what I mean. Either way it F****s up your sensors!!
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
