Seafoam spots a problem. Now what?
Old Nov 19, 2004 | 12:06 PM
XeroX's Avatar
Hella internets
I ran seafoam thru the max (brake booster) last weekend, and it started smoking from my engine bay. I noticed the smoke was coming from under the heat sheild coverint the front exaust manifold. Seafoam was spewing out as well..
My friend recomended it was just a gasget that needed to be replaced. But how can i do that? do i have to take out the whole exaust piping to replace this thing? Could it be more than just a gasget?
BTW, it also makes a put put put sound when exelerating from the front of the car, and when its in drive u can hear it rattling a bit from the outside of the car. Maybe the bolts came loose?
I need help!!! argghh...
Old Nov 19, 2004 | 12:10 PM
mzmtg's Avatar
Minister of Silly Walks
g-a-s-K-e-t
Old Nov 19, 2004 | 12:11 PM
Jeff92se's Avatar
I'm needing a caw
exhaust leak. Identify the source. If it's a gasket, replace. If it's the pipe, replace.
No one is going to be able to give advice if the source of the leak is unknown
Old Nov 19, 2004 | 12:14 PM
GodFather's Avatar
Made in Taiwan
yup, gasket is leaking, exhaust might be leaking, or you might have a leak somewhere in the engine. hopefully, it's just the gaskets. you might want to go to a muffler shop to replace them, it's a ***** when i had to do mine.
and that put put sound is normal when you run seafoam. there are too much carbonation impurites picked up by the seafoam. just press the pedal to rev the engine a couple of times. it should turn out pretty good after that.
DAVE Sz's Avatar
Hooooooonda.....
It's the crush ring between the y-pipe and the exhaust manifold. Time to get a new y-pipe.
Old Nov 19, 2004 | 12:15 PM
XeroX's Avatar
Hella internets
I have been searching, and have been reading about exaust manifold bolts snapping? Now that i think of it tho, is this a problem on then 1-3rd gens? i cant remember if they were posts for 4th gens or not.
BTW were you correcting my spelling? or aiming me towards replacing the "GAS-G-ET" lol
Old Nov 19, 2004 | 12:18 PM
XeroX's Avatar
Hella internets
the put put put sound happens before and after the seafoam tho, I know what it sounds like with seafoam getting sucked in lol...
As for the gasket for the y-pipe, isnt that lower in the engine bay? the smoke was coming from under the heat shield from where the pipes meet the exaust manifold...correct me if thats wrong as realy dont know..
Old Nov 19, 2004 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
Holy cripes man. You got over a 1,000 posts? You need to read the stickies everyday for a week, copy them out and read them again before bedtime
Click this and put this into your favorites
http://www.motorvate.ca/mvp.php/519
Old Nov 19, 2004 | 12:32 PM
2k2kev's Avatar
It's chrome alright...
Seafoam dun braked ur whip!
Old Nov 19, 2004 | 12:39 PM
XeroX's Avatar
Hella internets
naa, ive heard the sound b4...thought it was normal...
The seafoam helped me realize what the sound actually was. its a little bit louder now since i guess the deposits that built up were burnt up by the seafoam....
At first i thought it did lol...
As for the FAQs...i didnt think exaust leaks were covered in there...i guess a y-pipe install is in there...but why would i look at that? but thanks for the tip i guess it would help me understand what he is talking about..
Old Nov 19, 2004 | 12:48 PM
XeroX's Avatar
Hella internets
What does this have to do with what my problem is? I have a cali spec max, so the y-pipe doesnt have the last bend, so i am assuming that it is defanantly no where near where my leak is. Like i said this leak is coming from the front exaust manifold. looks like somewhere between the stock headers and the manifold. i cant really tell because its under the heat shield and i havent taken it off...
Thanks for trying to help tho, any other peices of advise?
and what about the exaust manifold bolts snapping.. could this be a possibility?
Old Nov 19, 2004 | 01:20 PM
Guinader's Avatar
funny you posted this, I just had the same problem, while with the open hood I saw the smoke coming out from the engine, and I tried to look for the place, but for me it seamed like it was the smoke coming from the exaust tip, but the wind was bringing the smoke up trough the engine bay. at least that is what I thought.
BTW I said funny because I did the seam foam, just last week also, on this past few warmer days.
Old Nov 19, 2004 | 01:34 PM
XeroX's Avatar
Hella internets
Yea, at first i thought it was from the tail pipe...but then i looked under the car and noticed a leak (seafoam) i spottet where it was coming from and it was coming from behind the heat sheild in the front of the engine. Kinda scared me lol..
Old Nov 19, 2004 | 01:36 PM
Jeff92se's Avatar
I'm needing a caw
Put more in, put the car on ramps, secure very well, start car, make smoke, look to see exactly where it's leaking.
Old Nov 19, 2004 | 01:51 PM
XeroX's Avatar
Hella internets
I was going to do this, but can you take off that heat sheild without taking EVERYTHING out? I have never worked down there b4 so i dont really know what to expect.
Old Nov 19, 2004 | 03:24 PM
mansurxk's Avatar
if you do use the seafoam, itll tell you around wwhere the leak is coming from. then worry about if its behind the heat shield or not, because i think you'd have to take it off anyway if you can see thats where its coming from.
Old Nov 20, 2004 | 12:28 AM
maximaintheface's Avatar
you can take the heat sheild off without taking the manifold off its like 3 or 4 bolts
Old Nov 20, 2004 | 06:28 AM
2 Da Max's Avatar
so do you feel an improvement with the seafoam?
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
