Tranny Flush
Old Nov 24, 2004 | 07:24 PM
vahmed's Avatar
Tranny Flush
I am planing on doing my tranny flush tomorrow just wondering how would I know which is the return line so I could drain the oil left in the system. -Thanks.
Old Nov 24, 2004 | 07:31 PM
f550maranello2's Avatar
just drain the torque converter, then the tranny and make sure u put in a new filter and gasket. goog luck!
Old Nov 24, 2004 | 08:00 PM
amulla01's Avatar
in my opinion, who cares about draining the return line? the real deal draining is done by the dealers with their speacial machine. if u are on time with your fluid changes, then its enough to drain the old fluid and put in the new one. i dropped my pan and cleaned it inside, but thats because i never did fluid change before that and it was quite dirty.
Old Nov 24, 2004 | 08:01 PM
amulla01's Avatar
oh and the worser problem than return cooler line is removing that nut off the filter to remove the filter. i couldnt do it on mine, and manual says u need to remove some part of transmission to take that off. good luck
Old Nov 25, 2004 | 06:38 AM
vahmed's Avatar
Thanks for the replies. I just bought this 97 max and I dont know if the transmission was ever flushed + I have the synthetic blend that I wanted to switch over to.
Old Nov 25, 2004 | 07:51 AM
njmaxseltd's Avatar
All the info you need is right here. http://forums.maxima.org/showthread.php?t=149056
Old Nov 25, 2004 | 08:11 AM
MDeezy's Avatar
there is a filter that need to be replaced with the AT Max's?
DO the 5Speeds have this also? I read the write up on tranny fluid change for the MT Max's it was just drain, and refil no mention of any filter.
Old Nov 25, 2004 | 11:28 AM
UncleMax98's Avatar
The return hose is above the out-going hose. On the transmission case, there are two metal tubes. The lower tube has a Banjo bolt. ATF fluid goes out from this tube toward the radiator cooler and return to the transmission via the upper metal tube.
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
RWCreative
Sep 21, 2015 11:01 AM
pktaske
Sep 4, 2015 08:40 AM
