Security light?
Old Nov 25, 2004 | 09:09 AM
97maxxx's Avatar
Security light?
I wanted to change the security light color from stock ugly red to blue and i was just wondering if it was a red led or just a white one with like one of those lil red covers on it -let me kno and also how do i go about getting to it -just prying off that slot or... thanks
Old Nov 25, 2004 | 09:28 AM
2 Da Max's Avatar
its a red led, just get another color and solder it on, check out igobuks thread
Old Nov 25, 2004 | 09:33 AM
97maxxx's Avatar
ight thanks how do u get to it?
Old Nov 25, 2004 | 09:46 AM
2 Da Max's Avatar
just take a flathead screwdriver, put it between the security light tab and the cruise control tab, and pull it out. then your going to have to take the screwdriver and push it around the little clip parts around the box after you take it out
Old Nov 25, 2004 | 11:12 PM
Igobuk's Avatar
When you do change the LED, you'll see that the stock one is mounted on a little rubber base that can just be pulled off. Inside this rubber base is a tiny resisitor. I tried re-using the base and stock resistor to save time but found it annoying to handle and just soldered on a resistor and LED instead.
Took less time and is more secure to solder, just test which one positive and negative. While I was at it, I made sure the new LED went up all the way against the face instead of sitting flush on the base like the stock LED. This made a big difference in brightness. The new LED sits high off the base compared to the stock one.
When I put the new LED flush like the stock one, it made the circle light up white, but when I put it up against the face, it was WHITE !! Below is a pic.
Old Nov 26, 2004 | 08:58 AM
97maxxx's Avatar
thanks man also is there any kind of specific led that is needed b/c i have one from another project that is very bright and i wanted to use that
Old Nov 26, 2004 | 11:10 AM
TJ_Max's Avatar
Paradox Systems Vendor
i changed to blue, i just snipped off the old led, and put my 6kmcd 5mm, blue led in there.....and i soldered mine on....
Old Nov 26, 2004 | 12:14 PM
97maxxx's Avatar
thanks again just got done doing it up- looks great -does the cruise control have the same led in it and can be changed out the same way?
Old Nov 27, 2004 | 06:13 AM
Igobuk's Avatar
The cruise control has 2 light bulbs, not LED's. I changed the one that lights up "cruise cont" but not the other one as it'd blind me at night. You can also solder in an LED like I did the security light, just take your time putting it back together. It's the second hardest after the hazard button.
Old Nov 27, 2004 | 07:07 AM
MDeezy's Avatar
how . . .
How did you test the led? Multimeter? How was the LED be tested (it acutally light up) before putting it into the car, so a fues or something doesnt blow, incase something was wired up wrong?
Old Nov 27, 2004 | 09:08 AM
2 Da Max's Avatar
just test it out with the led, if i doesnt work, switch the positions
Old Nov 27, 2004 | 10:33 AM
MDeezy's Avatar
sweet. I just poped mine out of the car. The grey rubber surrounding it, did you cut it or break it or is there a non destructive way of getting it off?
thanks.
Old Nov 27, 2004 | 01:42 PM
maxfun's Avatar
thanks.
you can just pull off the entire unit (red led with rubber base). Once it is off you will see that the lead for the red LED is just wrapped around the rubber base so as to make contact with the contact. From here you can just unwrap the lead off of the LED.
Old Nov 27, 2004 | 01:48 PM
madmax96's Avatar
where can i get a blue led light for this and what is there a number i should get
Old Nov 27, 2004 | 03:11 PM
maxfun's Avatar
Radio shack sells LEDs, granted you will get ripped off, but for just one LED and one resistor you will be fine. you will probably pay about 4 bucks for a resistor and an LED from radio shack. There is not a part number, just look at the brightness measured in mcd's. I am using a fairly bright one at 6000, but you don't need something that bright, but i wouldn't go too low either. I would say something above 500 mcd's. Also, if you plan on doing more led's order online from somewhere that gives volume discounts. I use Newark, but there are others.
Old Nov 27, 2004 | 05:19 PM
MDeezy's Avatar
yea radio shack is $3.99 for a 3000mcd blue or red led, resistors are $.99.
I think they have a 500 mcd led for 1.49 but that might not be bright enough.
Old Nov 27, 2004 | 06:56 PM
hollaatchaboi's Avatar
So if i want to chanfe the existing red LED to a blue one, do I have to solder in a resistor also? How many ohms should the resistor be? On which side do you solder the resistor (positive or negative)?
Old Nov 27, 2004 | 06:57 PM
madmax96's Avatar
thanks im going to try one first anf if it turns out good i want to do hazards and other lights on dash
Old Nov 27, 2004 | 09:19 PM
Maximasevspec's Avatar
i kept the grey peice when i did myn. I carfully puled out the old LED and inserted the new one in the exsact same position and used needle nose plyers to bend the prongs. I didnt have any Resistors laying around and i was to lazy to buy some so i used the stock houseings and stock resistor.
Old Nov 28, 2004 | 07:49 AM
2 Da Max's Avatar
i just did mine and it looks great! now im waiting for these stupid leds from japan
Old Nov 28, 2004 | 08:32 AM
MDeezy's Avatar
hmmm
ordered your off ebay?
I am wondering this too, I think the resistor is soldered to the negative side ( some one please correct me if I'm wrong on that)I'd guess when you get the resistor off and your going to buy a new one, try to match up the colors (brown orange red) then you should have the same type resistor needed.
unless we need a stronger resistor if we up the brightness of the LED.
yea some numbers would be benificial, or color code for resistors
Old Nov 28, 2004 | 07:05 PM
Igobuk's Avatar
I've used 3mm and 5mm LED's both with 470 ohm resistors. Worked great. You can solder the resistor to either the positive or negative end, doesn't matter as long as it has one.
Old Nov 28, 2004 | 07:34 PM
2 Da Max's Avatar
yes i ordered 194 leds off ebay over a month now and no response
Old Nov 28, 2004 | 10:05 PM
RA030726's Avatar
I'm nutty for Nissans
my security light owns
Old Nov 28, 2004 | 10:44 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
That is nice, but i would only put two led's buls instead of 7. I think two would be nicer.
Old Nov 28, 2004 | 10:49 PM
bigx323's Avatar
cant see the pics
Old Nov 29, 2004 | 06:25 AM
Igobuk's Avatar
Originally Posted by bigx323
cant see the pics
Whenever I can't see the pics, I right click on the red X. When the menu pops up I left click on "show picture".
It works most of the time.
Old Nov 29, 2004 | 01:14 PM
RA030726's Avatar
only 2? oh c'mon! the more the better! i used 6 b/c thats how many slots are behind the guages for the PRND21....
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
