Battery Drain
Old Nov 27, 2004 | 04:20 PM
TBONE1045's Avatar
Battery Drain
Just Joined Maxima.org And Was Hoping You Could Help Me With A Problem. I Have A 96 Maxima And The Battery Drains Within 10-14 Days With The Car Being Driven 2-3 Times A Week. The Alternator Checked Out And The Battery Is New. I Put A 12v Test Light Between The Neg Battery Post And Cable To Locate Circuit That Is Draining The Battery. The Drain Is Coming From The Bcm And The Battery/ign Fuse. Both Have To Be Removed For The 12v Test Light To Go Out. Can You Help? What Function Does The Bcm And The Battery/ign Serve? What's My Next Step In Stopping The Battery Drain?
Old Nov 27, 2004 | 04:30 PM
DemonSpawn's Avatar
Take the batter to pep boys or something and have it tested. Just because it's showing 12V with a test light, doesn't mean that it has a complete charge. It may only be holding a partial charge which would cause it to go dead quickly.
Old Nov 28, 2004 | 05:06 PM
TBONE1045's Avatar
BATTERY CHECKS OUT, ANY OTHER ADVICE?
Old Nov 28, 2004 | 05:09 PM
DemonSpawn's Avatar
Hmmm ... did you actually have the battery checked? Only other thing I can think of is that you could have a bad voltage regulator, or something may not be turning off when you remove the key from the ignition.
Old Nov 28, 2004 | 05:14 PM
99se5spd's Avatar
a test light is not an accurate way to check for battery drain, you need to check it with an multimeter in the A (current/amp) setting. contact a nissan dealer to find what the max allowable drain is on the battery, it should be fairly low. there is always going to be some drain on a battery. first thing to check would be any aftermarket accessories in your car, after that, just like you were doing, pull fuses one by one. the bcm (body control module) will always need some power for memory purposes (clock, radio, alarm etc.)
Old Nov 28, 2004 | 05:15 PM
95VQ30's Avatar
I had that problem and Come to find out the light in the glovebox was faulty and always stayed on, replaced and everything is fine now. Have you checked your ECU for a code yet? good luck.
TBONE1045's Avatar
Something is not turning off and it is connected to the BCM(?) fuse circuit and the Battery/IGN(?) fuse circuit.
Old Nov 28, 2004 | 07:40 PM
jackiss2888's Avatar
Tbone, I can only imagine how long it took you to type that crap in...
Old Nov 29, 2004 | 07:29 PM
TBONE1045's Avatar
STAY IN SCHOOL YOUNG MAN, YOU REALLY NEED TO CONTINUE YOUR EDUCATION.......
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
