No power when accelerating????
Old Nov 27, 2004 | 06:54 PM
maximusgee's Avatar
When I start accelerating it seems like I do not have the same power that I did before. Car miles is 74,000. Does anyone know what can be causing this? any ideas??
Old Nov 27, 2004 | 07:06 PM
mansurxk's Avatar
knock sensor failed
Old Nov 27, 2004 | 07:28 PM
Conrad283's Avatar
I need a truck
Have you done any mods recently?
Old Nov 27, 2004 | 07:29 PM
DemonSpawn's Avatar
Most likely the knock sensor ... check for CEL codes.
Old Nov 27, 2004 | 08:08 PM
maximusgee's Avatar
I have not done any MODS to the car.
How much is the knock sensor, and where can I get one cheap? Is this a hard task to do myself? Can the loss of acceleration be from bad spark plugs?? I am really clueless at this point. I need some help.
Old Nov 27, 2004 | 08:11 PM
Terran's Avatar
Don't just replace the KS. Check your codes. It's about $100 and is very doable. How many miles do you have? A general tuneup probably isn't a bad idea if it's been awhile.
Old Nov 27, 2004 | 08:13 PM
Conrad283's Avatar
I need a truck
Make sure the engine is cool before changing the KS.
Old Nov 27, 2004 | 08:28 PM
maximusgee's Avatar
74,000 miles, and thanks for the info
Old Nov 27, 2004 | 08:33 PM
99 SE-L
Ye, probably the KS
Old Nov 27, 2004 | 09:02 PM
Jatan's Avatar
Have you had a tuneup done before? (Plugs, air filter, fuel filter, PCV valve, clean TB, etc.)
Old Nov 28, 2004 | 12:29 AM
Ninos_Maxima's Avatar
be the change u want2C
The most common thing would be your KS, What year is your maxima?
Old Nov 28, 2004 | 01:06 AM
happyricefob's Avatar
V^___^V
http://forums.maxima.org/showpost.ph...3&postcount=42
Old Nov 28, 2004 | 06:54 AM
maximusgee's Avatar
1998 Maxima thanks for the help. I am going to check my codes, and get a tune up. I will lyk how it goes.
Old Nov 29, 2004 | 05:04 PM
viktornguyen's Avatar
I have the same problem, would a bad knock sensor trigger SES light on?
Old Nov 29, 2004 | 05:05 PM
dgeesaman's Avatar
Maintenance Monster
No. The KS triggers no lights, but if you check the CEL codes it will be there. And knock sensor replacement is not hard with the right pivoting socket and extension.
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
